Spatt Posted April 20, 2015 Share Posted April 20, 2015 Hi Folks.. its that time again.. Had Motul last time around but going for the "Forum Recommended" oil this time.. there are two prices for it though, can someone clear this up. Why is this: http://www.opieoils.co.uk/p-60169-silkolene-pro-s-5w-30-ester-synthetic-oil-for-high-performance-engines.aspx Different to this: http://www.opieoils.co.uk/p-68896-fuchs-titan-race-pro-s-5w-30-ester-fully-synthetic-engine-oil.aspx One says "For high performance engines" does this mean me? Also are the K 'n' N oil filters worth the money? I change my oil twice a year so i'm thinking no but maybe i need it for the oil above? Thanks in advance.. I didn't realise the oil required was fully synthetic either thought it was semi-synthetic Matt Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 20, 2015 Share Posted April 20, 2015 Both exactly the same. It used to be called silkolene but changed the Fuchs Titan. I've used it for years and would recommend it. Go for the second link, as you get a litre free at the moment. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 20, 2015 Share Posted April 20, 2015 Also the OEM Nissan filter is highly regarded and recommended by most. I usually use the OEM filter, but have currently got the k&n fitted as I ordered it with the oil for ease. No way of telling what is better, but the k&n has a handy hex nut on, when it comes to removal if you've over tightened it. Quote Link to comment Share on other sites More sharing options...
