Ali_z33 Posted April 16, 2015 Share Posted April 16, 2015 Hello z fans. I noticed a problem with my zed today, the chair reclines backwards but wont return to normal upright position anymore. The other button still works to move the seat forward and back. As you can imagine, this was a very uncomfortable ride home! 2007 350z model. Any suggestions? or is a replacement motor looking most likely? Thanks, Alistair Quote Link to comment Share on other sites More sharing options...
veilside z Posted April 16, 2015 Share Posted April 16, 2015 I would say it is the switch personally. Can you swop the two around to see if it is the switch, so the recline switch is using the sliding seat feed. Quote Link to comment Share on other sites More sharing options...
Ali_z33 Posted April 16, 2015 Author Share Posted April 16, 2015 Thanks for the suggestion. Any idea how to swap the switches. Sounds a bit technical. Quote Link to comment Share on other sites More sharing options...
benjy88 Posted April 17, 2015 Share Posted April 17, 2015 I have this problem on mine... exactly the same in fact, at first it just needed to be pushed forward a few times very quickly and then it worked, but now it doesn't work at all... Luckily I managed to get it into the right position before it conked out. If you find a solution, let me know! Quote Link to comment Share on other sites More sharing options...
veilside z Posted April 17, 2015 Share Posted April 17, 2015 Can't you leave the switches in situe and just swop the feeds around. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 18, 2015 Share Posted April 18, 2015 Can't you leave the switches in situe and just swop the feeds around. Tunnel comes off easy enough, 2 screws at the back, 2 at the front and a hidden one in the coin holder from memory... I think the centre dash has to come off first though, and obviously the gear surround... handbrake just pull up as far vertical as you can, then unclip the switches at you go Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
richard.hezlett Posted April 18, 2015 Share Posted April 18, 2015 Can't you leave the switches in situe and just swop the feeds around. Tunnel comes off easy enough, 2 screws at the back, 2 at the front and a hidden one in the coin holder from memory... I think the centre dash has to come off first though, and obviously the gear surround... handbrake just pull up as far vertical as you can, then unclip the switches at you go Sent from my iPhone using Tapatalk Can't you leave the switches in situe and just swop the feeds around. Tunnel comes off easy enough, 2 screws at the back, 2 at the front and a hidden one in the coin holder from memory... I think the centre dash has to come off first though, and obviously the gear surround... handbrake just pull up as far vertical as you can, then unclip the switches at you go Sent from my iPhone using Tapatalk +1. I removed my tunnel last month to swap round the heated seat switches. Exactly as above and yes there is a screw hidden underneath the ashtray/coin holder. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 18, 2015 Share Posted April 18, 2015 Can't you leave the switches in situe and just swop the feeds around. Tunnel comes off easy enough, 2 screws at the back, 2 at the front and a hidden one in the coin holder from memory... I think the centre dash has to come off first though, and obviously the gear surround... handbrake just pull up as far vertical as you can, then unclip the switches at you go Sent from my iPhone using Tapatalk Can't you leave the switches in situe and just swop the feeds around. Tunnel comes off easy enough, 2 screws at the back, 2 at the front and a hidden one in the coin holder from memory... I think the centre dash has to come off first though, and obviously the gear surround... handbrake just pull up as far vertical as you can, then unclip the switches at you go Sent from my iPhone using Tapatalk +1. I removed my tunnel last month to swap round the heated seat switches. Exactly as above and yes there is a screw hidden underneath the ashtray/coin holder. Nice to see my memory hasn't gone.... yet Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
