Remapped! Good gains, but cracked HFC's...
AdrianL
Got the car MOT'ed and mapped today. Before map was 265bhp and after 293.8bhp so pretty happy!
However they mentioned that both high flow cats are cracked. Is this a common issue for HFC's? or is it just the ones I have are crap? (no idea what brand).
Not leaking yet fortunately but need to sort!.
Cheers!
Adrian
Do you still have the OEM Cat brace to support them or not?
Just wondered if that might be what's caused them to crack where they have if you don't have the support. :dry:
I'd say see if you can get them re-welded before the crack gets any worse. ;)
Not that common to crack them - but like anything it can and does happen.
What Y pipe have you got? The ones without flexis put more vibration into the CATs.
Get those welded ASAP they should be OK.
Sweet. Will deffo find an exhaust place to weld them up :)
Got it mapped at RS tuning in Leeds. Definitely happy with the gains!!
Engine mods are:
Injen air intake with kinetix upper plenum (filter is located behind front bumper)
Borla high flow headers
High flow cats
HKS full stainless cat back
Engine grounding kit
Think that's it. It was running 265bhp before the map, so it lost a few horses over the years.
Edited by AdrianL
Even Berks crack, I know from experience :)
Decats? If so that supports the brace issue mentioned before :)
HFCs and not sure, they cracked along the seam just like in your pic, got the, welded up and they were fine
Well the bloody CEL came back on today!! Did a few shorter trips without a light after the remap, but did 75 miles this weekend on the motorway, and when I started it up again the CEL came back on after a bit. This time the code is P1273 - no other codes but that one. Could it be related to the crack in the welds?
Well my CEL came on now and again before I had the crack welded, once it was done I never saw it again :)
