-Bradders- Posted April 14, 2015 Author Share Posted April 14, 2015 I give in, i changed the oil again last night back to 5w30, reseated the plugs in 5-6, was fine on idle for about 15 mins, then started smoking bad again. Booked in with sly for the weekend! Quote Link to comment Share on other sites More sharing options...
Grundy Posted April 14, 2015 Share Posted April 14, 2015 Good luck buddy 1 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 14, 2015 Share Posted April 14, 2015 At least you'll know what's causing the issue after he's looked it over. I think you were a bit daft for driving it hard whilst it's clearly not well, hopefully it's nothing serious at all Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 14, 2015 Author Share Posted April 14, 2015 At least you'll know what's causing the issue after he's looked it over. I think you were a bit daft for driving it hard whilst it's clearly not well, hopefully it's nothing serious at all It still drives perfect though, no missing no nothing. its spot on. just smoking a lot, when i changed the oil 4.5 litres came out. thats pretty much what i put in 600 miles ago, barr the oil filter. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 14, 2015 Share Posted April 14, 2015 At least you'll know what's causing the issue after he's looked it over. I think you were a bit daft for driving it hard whilst it's clearly not well, hopefully it's nothing serious at all It still drives perfect though, no missing no nothing. its spot on. just smoking a lot, when i changed the oil 4.5 litres came out. thats pretty much what i put in 600 miles ago, barr the oil filter. I wonder what the heck it is though, just seems weird that it's happened after plug/oil change. Then again one of my compression arms started knocking immediately after I changed the suspension, so could just be random timing. Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 14, 2015 Share Posted April 14, 2015 Potentially valve seals. Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 14, 2015 Author Share Posted April 14, 2015 Potentially valve seals. thats what i was thinking. or a sticky valve as when its first started its ok. only after a bit it starts chugging. i was on par with the jet car at santa pod lol Quote Link to comment Share on other sites More sharing options...
Dicky Posted April 15, 2015 Share Posted April 15, 2015 Did you check the PCV as Alex suggested in page 2. There's a vid on YouTube showing how to check their operation. If that's not working you will get smoke 1 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 16, 2015 Author Share Posted April 16, 2015 link? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted April 16, 2015 Share Posted April 16, 2015 (edited) Presume it needs to be at running temp before it smokes? Does it smoke all the time even at idle? Edited April 16, 2015 by Mark@Abbey m/s Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 16, 2015 Author Share Posted April 16, 2015 Presume it needs to be at running temp before it smokes? Does it smoke all the time even at idle? nope im starting to think its leaking in oil somewhere as its worse when its been left for a night or 2 as if its all settled somewhere then blows it out on startup?? Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 16, 2015 Author Share Posted April 16, 2015 and yeah smoke on idle or throttle. worse on idle tbh. unless booting it Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 16, 2015 Share Posted April 16, 2015 link? Linky 1 Quote Link to comment Share on other sites More sharing options...
Dicky Posted April 16, 2015 Share Posted April 16, 2015 Not to good with this sort of thing so hope this link works. Good luck with it. 1 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 16, 2015 Author Share Posted April 16, 2015 Just had a brain wave... i changed the oil filter, im pretty sure the oil filter is suppose to have a valve in it no? what if euros gave me a general one? would that cause smoke? Cheers. Brad Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 16, 2015 Share Posted April 16, 2015 Find out what one they gave you JUST in case (although I'd assume they are roughly the same no?). I've used a Nissan one, one from Clark and just a few weeks ago one from Opie oils. Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 16, 2015 Share Posted April 16, 2015 No valve on the Zed oil filter. It's just a plain ol' lump. 1 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 16, 2015 Author Share Posted April 16, 2015 thought there was an anti drain back val e??? Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 16, 2015 Share Posted April 16, 2015 It's a bog-standard filter for Jap cars, tbh there's at least 10 that I can think of that fit, just depends on the capacity you want from it. The same one that fits the Zed fits the Impreza, the MR2, the Mini... Proven and tested Trust me, that's not your issue. If the filter fitted, then it's fine. 1 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 16, 2015 Author Share Posted April 16, 2015 ta Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted April 17, 2015 Share Posted April 17, 2015 Strange that it smoked after you changed the oil. Also strange your now saying it has not used any oil but has been smoking heavily. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 17, 2015 Share Posted April 17, 2015 Booked in with sly for the weekend! Best thing I have heard, he will get to the bottom of it, fingers crossed it isn't terminal Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
coldel Posted April 19, 2015 Share Posted April 19, 2015 ...any update mate? Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 20, 2015 Author Share Posted April 20, 2015 Nah its in with sly tomorrow, i took it there saturday to leave it there as i dont have time during the week Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted May 7, 2015 Author Share Posted May 7, 2015 Small update, took it to sly, he says its rings or worse, took it to another guy, he says deffo valves. **** this, im getting another engine. lol Quote Link to comment Share on other sites More sharing options...
