TT350 Posted May 12, 2015 Author Share Posted May 12, 2015 Ah right that's not bad then very good price! All I would say is mates doing work for you always ends up hassle unless they are reliable. Every time mates do work for me it takes aggggeeesss although the price is normally good. Get it done! Be nice to see it progress He's pretty speedy. Said it'd take a week max. On another note, I'm going to buy a 1.0 Yaris today Quote Link to comment Share on other sites More sharing options...
TT350 Posted May 14, 2015 Author Share Posted May 14, 2015 Bought the Yaris. I haven't driven anything with less than 170 bhp in a long long time. I was a bit overwhelmed by how slow the Yaris is to the point of being concerned it was faulty lol. But. It's comfy. The stereo is surprisingly good. It has basic early sat nav. AC. Toyota claims 49mpg. Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 14, 2015 Author Share Posted August 14, 2015 Things are happening Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 25, 2015 Author Share Posted August 25, 2015 Bearing gone deep in the engine. Wahey! Will be off the road for a couple of months. On the plus side I've been liasing with Torqen and he's sourced a shortblock for me which is capable of 650whp. That should arrive in 3 months. Specs are; Stage 1 Short Block up to 650rwhp 8.8:1 compression Wiseco Pistons .020 over Eagle/SCAT H Beam Rods ARP Rod Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Block water passage cut for HR Headgaskets Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled ARP VQ35 Main Stud Kit Ceramic/Moly Piston Coating 350z DE Short Block Core Charge I'm thinking in the meantime I will slowly take apart the engine for when it goes into TDI North to drop the shortblock in. Save some time and money on labour plus it'll be interesting to do. I have plenty of mechanic friends if I get overly buggered but I'll try my best. On top of that Torqen will be supplying clutch rated to 715ft/ib, 6 x 1000cc injectors, gaskets etc. And a lovely 380mm big brake conversion. Beautiful. The 380mm discs will necessitate 19" wheels which I always planned to get anyway. They'll probably be Work VSXX. On top of that I'm thinking Vertex front bumper and sideskirts and chargespeed rear bumper and a respray in championship white. Kind of an off white. So should be complete by the beginning of summer and maybe a grand unveiling at a meet. Toyota Yaris in meantime. Save some money on fuel lol. 1 Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 25, 2015 Share Posted August 25, 2015 Bearing gone deep in the engine. Wahey! Will be off the road for a couple of months. On the plus side I've been liasing with Torqen and he's sourced a shortblock for me which is capable of 650whp. That should arrive in 3 months. Specs are; Stage 1 Short Block up to 650rwhp 8.8:1 compression Wiseco Pistons .020 over Eagle/SCAT H Beam Rods ARP Rod Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Block water passage cut for HR Headgaskets Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled ARP VQ35 Main Stud Kit Ceramic/Moly Piston Coating 350z DE Short Block Core Charge I'm thinking in the meantime I will slowly take apart the engine for when it goes into TDI North to drop the shortblock in. Save some time and money on labour plus it'll be interesting to do. I have plenty of mechanic friends if I get overly buggered but I'll try my best. On top of that Torqen will be supplying clutch rated to 715ft/ib, 6 x 1000cc injectors, gaskets etc. And a lovely 380mm big brake conversion. Beautiful. The 380mm discs will necessitate 19" wheels which I always planned to get anyway. They'll probably be Work VSXX. On top of that I'm thinking Vertex front bumper and sideskirts and chargespeed rear bumper and a respray in championship white. Kind of an off white. So should be complete by the beginning of summer and maybe a grand unveiling at a meet. Toyota Yaris in meantime. Save some money on fuel lol. Sorry to hear that Although this all sound epic Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 25, 2015 Author Share Posted August 25, 2015 Bearing gone deep in the engine. Wahey! Will be off the road for a couple of months. On the plus side I've been liasing with Torqen and he's sourced a shortblock for me which is capable of 650whp. That should arrive in 3 months. Specs are; Stage 1 Short Block up to 650rwhp 8.8:1 compression Wiseco Pistons .020 over Eagle/SCAT H Beam Rods ARP Rod Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Block water passage cut for HR Headgaskets Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled ARP VQ35 Main Stud Kit Ceramic/Moly Piston Coating 350z DE Short Block Core Charge I'm thinking in the meantime I will slowly take apart the engine for when it goes into TDI North to drop the shortblock in. Save some time and money on labour plus it'll be interesting to do. I have plenty of mechanic friends if I get overly buggered but I'll try my best. On top of that Torqen will be supplying clutch rated to 715ft/ib, 6 x 1000cc injectors, gaskets etc. And a lovely 380mm big brake conversion. Beautiful. The 380mm discs will necessitate 19" wheels which I always planned to get anyway. They'll probably be Work VSXX. On top of that I'm thinking Vertex front bumper and sideskirts and chargespeed rear bumper and a respray in championship white. Kind of an off white. So should be complete by the beginning of summer and maybe a grand unveiling at a meet. Toyota Yaris in meantime. Save some money on fuel lol. Sorry to hear that Although this all sound epic Thanks for the condolences lol. But yes it should be good when it all comes together. Be a hard and long wait though Quote Link to comment Share on other sites More sharing options...
Ogman Posted August 25, 2015 Share Posted August 25, 2015 Looking forward to this! Btw, the 380mm BBK fit under the standard Rays 😊 running them on mine fella. Minimal clearance but hey, who needs clearance!? It's almost like they were made to fit! Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 25, 2015 Author Share Posted August 25, 2015 Looking forward to this! Btw, the 380mm BBK fit under the standard Rays 😊 running them on mine fella. Minimal clearance but hey, who needs clearance!? It's almost like they were made to fit! Sent from my iPhone using Tapatalk Ahh that's good to know. Can get that all done before the bodykit/paint/wheels then as I wanted to do the aesthetic things all together which obviously means wheels and as I thought I needed 19s minimum then I thought I'd have to do brakes last. Which wouldn't be good with 650hp at the wheels and my heavy right foot lol. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 25, 2015 Share Posted August 25, 2015 What power was you at when it went wrong Is it a de Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 25, 2015 Share Posted August 25, 2015 Wow that's a good list of mods! This will be very very fast once finished . What sort of money is the built engine? Pm if needed . Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 25, 2015 Share Posted August 25, 2015 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 25, 2015 Share Posted August 25, 2015 Back at you Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 25, 2015 Share Posted August 25, 2015 Josh and Adrian sitting in a tree k.i.s.s.i.n.g Then pops out a built engine baby Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 25, 2015 Share Posted August 25, 2015 ...... Hay if that's what it takes I was actually a bit confused from the wink ? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 25, 2015 Share Posted August 25, 2015 Nic, jealous again? Josh, honey... Let's do it on PM! Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 25, 2015 Share Posted August 25, 2015 Nic, jealous again? Josh, honey... Let's do it on PM! Adrian no love me any more Lol Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 25, 2015 Share Posted August 25, 2015 Nic, jealous again? Josh, honey... Let's do it on PM! We are through you 2 timing Dirty ho . What's my options you slag ? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 25, 2015 Share Posted August 25, 2015 (edited) Nic, jealous again? Josh, honey... Let's do it on PM! We are through you 2 timing Dirty ho . What's my options you slag ? What's the crack you buy a forged lump then send them yours Edited August 25, 2015 by nissanman312 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 25, 2015 Share Posted August 25, 2015 ..... No I think you just sell your engine on...... I would rather have someone build my engine if possible . Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 25, 2015 Author Share Posted August 25, 2015 What power was you at when it went wrong Is it a de 430bhp. Yes a DE. 1 Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 25, 2015 Author Share Posted August 25, 2015 Wow that's a good list of mods! This will be very very fast once finished . What sort of money is the built engine? Pm if needed . Have you PM'd Adrian? 1 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 25, 2015 Share Posted August 25, 2015 Sorry tt350 - just realised this is your build thread ! Sorry for the clutter and Adrian's flirting . Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 25, 2015 Author Share Posted August 25, 2015 (edited) Sorry tt350 - just realised this is your build thread ! Sorry for the clutter and Adrian's flirting . Lol It's ok. Looks like 6 of one and half a dozen of the other to me Edited August 25, 2015 by TT350 1 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 25, 2015 Share Posted August 25, 2015 These dirty Europeans like a good flirt before a purchase Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 25, 2015 Share Posted August 25, 2015 These dirty Europeans like a good flirt before a purchase Torqen business cards all over this phone box lol Quote Link to comment Share on other sites More sharing options...
