TT350 Posted June 30, 2017 Author Share Posted June 30, 2017 He does Flex. I've seen then. Went a bit far with the photoshopping, though. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 30, 2017 Share Posted June 30, 2017 Its ok Flex, I have them. We all do, ...just Google naked bear. Actually don't. 2 Quote Link to comment Share on other sites More sharing options...
Flex Posted June 30, 2017 Share Posted June 30, 2017 He does Flex. I've seen then. Went a bit far with the photoshopping, though. I can imagine Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 12, 2017 Author Share Posted July 12, 2017 Just when I thought it was out.... They pulled it back in!! Overheating problems. Sorted. Coolant leak. Brake lines....buggered. Having the lot redone. Quote Link to comment Share on other sites More sharing options...
philw99 Posted July 13, 2017 Share Posted July 13, 2017 Who's doing all the work for you? TDI North? Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 22, 2017 Author Share Posted July 22, 2017 On 7/13/2017 at 15:03, philw99 said: Who's doing all the work for you? TDI North? No. A place in Bury called R.E Performance. Great bunch of honest and helpful guys. Only thing is they're not speedy. But price and quality of service and workmanship overshadows that. Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 22, 2017 Author Share Posted July 22, 2017 I forgot just how completely lag free this kit is. Awesome. And the noise I think they've had the fuel pump out and not replaced the rubber seal. Strong smell of fuel when window is down and I'm moving because of the air pressure sucking fumes out of the window. No overheating. Everything is 100% except the clutch now! Stinky. 1 Quote Link to comment Share on other sites More sharing options...
Snjur Posted July 23, 2017 Share Posted July 23, 2017 Rubber seal tends to deform from fuel inside and special once you take it out return is not sealing properly again. Anyway oem is not much of a cost and is 10 min job to replace it Quote Link to comment Share on other sites More sharing options...
BobbyZ Posted July 23, 2017 Share Posted July 23, 2017 So how much power are you insured for? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted July 23, 2017 Share Posted July 23, 2017 Did you say clutch? Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 25, 2017 Author Share Posted July 25, 2017 On 7/23/2017 at 17:23, BobbyZ said: So how much power are you insured for? 450 is what it's at and declared to insurer. Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 25, 2017 Author Share Posted July 25, 2017 On 7/23/2017 at 21:07, Adrian@TORQEN said: Did you say clutch? It'll be ok for a while yet! Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 27, 2017 Author Share Posted July 27, 2017 Missfire. Intermittent. Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 27, 2017 Share Posted July 27, 2017 Random, or a particular cylinder? Quote Link to comment Share on other sites More sharing options...
TT350 Posted July 28, 2017 Author Share Posted July 28, 2017 On 7/27/2017 at 10:35, Ekona said: Random, or a particular cylinder? Haven't diagnosed which cylinder it is. It's very intermittent. It might not do it for a few hours and then it'll do it for 30 seconds. The plugs are grade 5 so might go up to 6 or 7 if it isn't wiring or a coil. Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 28, 2017 Share Posted July 28, 2017 Is it throwing a code, or can you hear/feel it? Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 6, 2017 Author Share Posted August 6, 2017 (edited) Knock knock. Who's there? Your rod bearings. We're going. And we're taking the £7k with us lol. Edited August 6, 2017 by TT350 Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 6, 2017 Share Posted August 6, 2017 4 hours ago, TT350 said: Knock knock. Who's there? Your rod bearings. We're going. And we're taking the £7k with us lol. You have to be joking Quote Link to comment Share on other sites More sharing options...
Redsky Posted August 6, 2017 Share Posted August 6, 2017 Wait rod bearings cost 7K? O.o that or what the hell did they take with them Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 6, 2017 Author Share Posted August 6, 2017 3 hours ago, nissanman312 said: You have to be joking No its knocking it's tits off again. Did 980 miles gently. Started yesterday. Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 6, 2017 Author Share Posted August 6, 2017 2 hours ago, Redsky said: Wait rod bearings cost 7K? O.o that or what the hell did they take with them No the bottom end was nearly 5k labour fitting it 2k. Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted August 7, 2017 Share Posted August 7, 2017 What oil have you been using? Was there plenty in it? Quote Link to comment Share on other sites More sharing options...
Wasso Posted August 7, 2017 Share Posted August 7, 2017 Hold on a mo didn't you buy a built bottom end? I'm confused here.... Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 7, 2017 Author Share Posted August 7, 2017 1 hour ago, Wasso said: Hold on a mo didn't you buy a built bottom end? I'm confused here.... Yes and that is now also knocking. Quote Link to comment Share on other sites More sharing options...
TT350 Posted August 7, 2017 Author Share Posted August 7, 2017 1 hour ago, The Chubby Ninja said: What oil have you been using? Was there plenty in it? Yes was plenty in. As for the oil, a more than suitable one but not sure which. I'll ask the guys that fit it. But I trust them. Quote Link to comment Share on other sites More sharing options...
