Brakes-What am I Missing?
Dicky
Sunny afternoon so decided to check and expected to have to change my discs(rotors) given they've done 70k now. When I measured the front rotor thickness (avoiding the wear lip at the edge) they were 28.3mm.
I looked at the workshop manual (BR section) and it says Standard(New) thickness 24mm, change at min thickness 22mm and quotes the Rotors as CLZ25VD.
I looked at my new Pagid rotors and they measure 30.5mm and stamped along the edge it says to replace at 28.3mm
What's going on. Either my vernier is all to **** (it seems fine) the manual is all to ****, I'm all to **** or my discs are getting fatter like me!!
Help, my brain hurts
Is that not the thicknesses for the JDM Brakes - not the Brembos?
No idea. The car is a UK version with a brembo abrakes, but when they talk about Brembo brakes does that just apply to the Calipers or does it include the rotors as well?
Just came across a 2004 spec on the net for Brembo brakes (which does include the a Rotors) and the thickness ( new) is quoted as 1.18" which is 30mm. So I assume there much the same as the Pagid Rotors, so I think I'm going to take the replacement thickness to be 28.3 as stamped on my new Pagid rotors.
Unless I here from someone who knows better
