Adrian@TORQEN Posted April 4, 2015 Share Posted April 4, 2015 (edited) TORQEN R coilover kit offers a great balance between fast road and track use. It is the perfect solution for the track days enthusiasts who need a suspension kit that is forgiving and comfortable enough for everyday road use, but also provides specific adjustments that can be dialled in before hitting the track. TORQEN R coilovers are fully height adjustable, allowing a drop of 50mm from standard height, even whilst installed to the vehicle. The additional reservoirs provide 2-way bump and rebound damping separate adjustment with 33 settings each, whilst the increased oil capacity improves heat dissipation for stable handling in extreme tracking and racing environments, enabling the damping force to have an optimal linear change. The locking rings are made from forged aluminum conferring increased durability. The McPherson struts use high rigidity 52mm shock body, with the rear struts including wave alloy steel thrust washers to ensure locking rings remained locked to the lower mounts and can not loosen over time. Springs are constructed from SAE-9254 cold-wound steel and are protected by a high strength surface coating. Spring bearings are mounted between the spring ring and top cap to improve handling agility and eliminate spring noise when cornering. The piston valves are matched to each spring rate. The piston stroke is tested 10 million times on advanced testing equipment, the equivalent of 5 years mileage. Each component of the suspension system is rigorously inspected and strictly tested to avoid any premature failure. TORQEN R coilover kit comes with a 1 year guarantee. In the kit: 4 x suspension monotube dampers 4 x SAE-9254 cold-wound steel springs Front: 10kg; Rear: 10kg 4 x damping force adjustment knobs 2 x high strength aluminium rear rubber joint mounts 2 x high strength aluminium front rubber joint mounts 3 x ride height adjustment spanners £1399 Edited July 20, 2015 by octet@TORQEN Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted April 4, 2015 Share Posted April 4, 2015 Look nice like the rest of your kitsðŸ‘. Send me a set over for proper testing and feedback.👀 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 4, 2015 Author Share Posted April 4, 2015 Look nice like the rest of your kitsí ½í±. Send me a set over for proper testing and feedback.í ½í±€ Thank you, as soon as they were paid for, you'll have them shipped 1 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 5, 2015 Author Share Posted April 5, 2015 Detailed photos added. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 30, 2015 Author Share Posted April 30, 2015 Read the awesome review of these coilovers being tested by our client John on Nurburgring, earlier this month: Click HERE Lead time 7-10 days. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted June 11, 2015 Author Share Posted June 11, 2015 Track days booked for this summer? These will help you a lot! Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted June 11, 2015 Share Posted June 11, 2015 :@ Quote Link to comment Share on other sites More sharing options...
