Bank Holiday Bath
Stutopia
So with a spare weekday laying around, I got up, put on my detailing pants (2000 grit gusset to keep you smooth :lol: ) opened the curtains and... rain :( Meteo projected a two hour weather window between 12 and 2, so I waited and watched. Usually I'd find something else to do but I'm busy the next three days and with a light hoon last weekend there was a kilo of brake dust on the wheels and an inch of GTR exhaust grime on the front which I have been desperate to shift all week.
Eventually the rain stopped and it almost looked like a clean car.
But last week's brake dust was definitely under there and...
... you can see those run lines that form on the haunches of a zed when it's been out in the wet for a spin.
A quick spritz with AMMO Plum Wheel Cleaner and then a once over woolie job with Envy Evolution wheel cleaner and there was a pleasant purple foamy pool on the floor and...
...an immacutale wheel underneath. These two products are nailed on brilliant. I won't be dabbling anymore on wheel cleaner, except what's in a WaxyBox.
Immacualte, if you ignore the crap they did't remove from the wheel weights when they were balanced :rant:
The run lines were still there after "snow foaming". I've used quotes as the foam was a mix of some envy shampoo and meguiars hyper wash nearly dead bottles I was using up, not a proper snow foam.
A proper TBW later and they were history.
The more I use Envy Shampoo, the more I like it. It's got great lubricity, cuts through grime, suds well, smells fine and leaves protection alone - perfect. (Fake beads used to check for run lines).
All dried off and I was set to hit her with some sealant and perform a very rare waxing, but then this happened :(
Usually there's a tower there, not just precipitation :( It did allow for a couple of fresh beads to form though :)
Still beading on three week old Gyeon WetCoat, topped with AMMO Hydrate drying aid a couple of weeks ago, no QD or wax on here for months.
Not got a final photo of the washed Shark as I was getting soaked and I'm hoping it might stop in bit and I can finish the job properly and lay down some more protection.
For no reason at all, other than I like it, gratuitous sexy Rays Engineering shot.
Edited by SuperStu
  • Like 4
Rays came up great. B)
Miss mine a little, ...if only I could have got the same style Rays in 19". :dry:
They're such a great wheel, they look good and they weigh nothing. It's a shame the offset isn't a bit more agressive as stock. I'd love to buy some other Rays for her, but for that kind of money you could have a track tart :lol:
It never got dry enough for long enough to add some protection, but I did get 20 minutes of dry with fading light to clean up the tips :)
Whatever anyone tries to tease you with, never stray from the Britemax Metal Twins. Before and afters :teeth:
Both done :)
