nissanman312 Posted March 28, 2015 Share Posted March 28, 2015 (edited) anyone near me weld alloy i need the holes on my gredy sump welding up like this http://www.the370z.com/diy-section-do-yourself/42072-diy-greddy-turbo-aluminum-oil-pan-additional-oil-cooling-option.html Edited March 28, 2015 by nissanman312 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 28, 2015 Share Posted March 28, 2015 Just an idea but failing finding anyone to weld them up could you not just fabricate two small metal plates to bolt over the holes with some gasket sealant sandwiched between the two to stop any leaks. Might be a job for the Zed shed (try a PM to Keyser or Buster if that's what you decide). 1 Quote Link to comment Share on other sites More sharing options...
evilscorp Posted March 28, 2015 Share Posted March 28, 2015 ^^^ come time to sell give's you a bigger market, or if you go turbo. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted March 29, 2015 Author Share Posted March 29, 2015 Just an idea but failing finding anyone to weld them up could you not just fabricate two small metal plates to bolt over the holes with some gasket sealant sandwiched between the two to stop any leaks. Might be a job for the Zed shed (try a PM to Keyser or Buster if that's what you decide). cheers guys ^^^ come time to sell give's you a bigger market, or if you go turbo. very true i just wasnt sure how it sits im thinking the holes sit outside the sump area then? sorry for my lack of savy on this stuff Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 29, 2015 Share Posted March 29, 2015 The whole engine is sealed by a big gasket and that's pumping oil round at much bigger pressures than what's sitting in the sump It'll be fine, and as said it's a much better idea than just welding them shut. 1 Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted March 29, 2015 Author Share Posted March 29, 2015 The whole engine is sealed by a big gasket and that's pumping oil round at much bigger pressures than what's sitting in the sump It'll be fine, and as said it's a much better idea than just welding them shut. cheers dan i think ill hand it all over to litchfeild and let them do what they see best Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted March 29, 2015 Share Posted March 29, 2015 I need to find my GTM blocking plates somewhere in the billion boxes and pots We can replicate these. I have this one, which is similar: http://www.the370z.com/engine-drivetrain/74397-gtm-performance-engineering-high-capacity-oil-pan-w-oil-baffling-system-8qts.html Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted March 29, 2015 Share Posted March 29, 2015 I'll need some of them also !! Quote Link to comment Share on other sites More sharing options...
