*** TORQEN *** 370z TORQEN S Coilovers
Adrian@TORQEN
Coilovers are also fully height adjustable and the ride height can be increased as well as decreased from standard. Springs are constructed from SAE-9254 cold-wound steel and are protected by a high strength surface coating in black. Each kit is fully height adjustable from stock height to up to 50mm lower. Dampers are monotube design. TORQEN S coilovers are damping force adjustable with 30 settings to choose from the dial.
In the kit:
4 x suspension dampers
4 x SAE-9254 cold-wound steel springs: Front 180mm 12kg; Rear 230mm 10kg
4 x damping force adjustment knobs
2 x high strength aluminium rear rubber joint mounts
2 x high strength aluminium front rubber joint mounts
2 x vehicle height adjustment spanners
2 x brake lines holders
ORDER HERE
Edited by Adrian@TORQEN
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
  • 3 months later...
