cmck13 Posted March 24, 2015 Share Posted March 24, 2015 I'm going on a trip around France Belgium and Holland, later this year, that's the good part, using either the euro tunnel or a ferry from Dover. I am worried about ground clearance getting on and off the ramps etc. My car by most standards has fairly liberal ground clearance of around 4 inches, or about 10 cm, under the front lip. What has been the experience from those who have used either way of this crossing and is there less of a problem on either of them? Thanks in advance for any advice. Quote Link to comment Share on other sites More sharing options...
mbs Posted March 24, 2015 Share Posted March 24, 2015 If it's standard no problem at all, done it many times, just take it slowly and if necessary at a bit of an angle. 1 Quote Link to comment Share on other sites More sharing options...
mbs Posted March 24, 2015 Share Posted March 24, 2015 If it's standard no problem at all, done it many times, just take it slowly and if necessary at a bit of an angle. Sorry didn't mention my experience is with the ferry, not used Eurotunnel Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 24, 2015 Share Posted March 24, 2015 The eurotunnel is how the german stance guys get to europe for shows so I'd imagine it's ok. When I went to holland on the ferry I got put in with the lorries as there's less ramps etc and I was fine 1 Quote Link to comment Share on other sites More sharing options...
docwra Posted March 24, 2015 Share Posted March 24, 2015 I do Eurotunnel regularly and have done Ferries too ........... .......... and thats a lot less than 10cm If youre on a ferry is might be worth letting them know you are low and they then put you in with the lorries but on Eurtunnel the loaders will send any low cars to the lower level anyway. My biggest problem is width, my wheels scrape down the tracks on the tunnel 1 Quote Link to comment Share on other sites More sharing options...
Pritchard Posted March 24, 2015 Share Posted March 24, 2015 4 inches, liberal?! lol. i catch nearly every speed bump with my lowered to 4inch clearence. last time i was on the eurotunne, i recall its quite flat / gradual ramp. i would be more concerned with the speedbumps in any of the carparks you find lol. never been on the ferry, but i do recall a top gear episode (RIP) where they got a car stuck on the out-ramp. 1 Quote Link to comment Share on other sites More sharing options...
Will370z Posted March 24, 2015 Share Posted March 24, 2015 If standard you should be fine. Eurotunnel is a little tight on the train so watch your alloys. Main issue with the ferry is protecting your car while the masses walk by after vacating their cars. Getting on and off should be fine 1 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted March 24, 2015 Share Posted March 24, 2015 Chunnel was no problem for my stock height Zed with a V1 replica lip, though I did have to do suggest the lower deck to the chap on the platform. The width of the track inside the train is much more worrying, even with Rays. 1 Quote Link to comment Share on other sites More sharing options...
Exotic Posted March 24, 2015 Share Posted March 24, 2015 Done Channel Tunnel many times and yes the tracks are tight with low profile tyres, wish they made the tracks just a little wider as I don't even thing the Zed is a very wide car. 1 Quote Link to comment Share on other sites More sharing options...
Lexx Posted March 24, 2015 Share Posted March 24, 2015 If you're worried, mention when you book that you are low clearance (even though if you have standard ride height, you really wouldn't have an issue). When I worked for DFDS if a car declared themselves as low we would stick them on the middle deck with the freight as there was no major lips to cope with. The standard tourist deck on the DFDS Dover - Dunkerque route is an absolute NO for low vehicles. 2 Quote Link to comment Share on other sites More sharing options...
cmck13 Posted March 24, 2015 Author Share Posted March 24, 2015 Thanks for the answers all taken on board, I think it will be the tunnel, spoke to a booking clerk and they say to mention to the locating marshal that you require the lower deck. They also quoted they don't want you to get stuck because that will b*gg*r up everyone behind you, enough said. Quote Link to comment Share on other sites More sharing options...
