JWT popcharger fitted & thoughts
rickya
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
want noise? shift down to 2nd and bury the throttle into the carpet...oh..dont forget to roll down your windows..
whilst in a tunnel! :teeth:
I do that every time through the tunnels in birmingham city centre. Slow right down to about 20mph and then floor it!! Its sounds like no other sound in the world. I miss my car violins.gif
ps has anyone found that their traction control is kicking off more often since fitting an air intake. I have found this definetley since I fitted mine, especially in 1st & 2nd gear, usually while pulling off after taking tight turns??
Probably more to do with your heavy right foot than an air take ;):lol:
Imo it's down to the weather an the greasy roads... Or possibly the Falkens, never experienced them in the cold till now!!!
SERVICING YOUR POP-CHARGER FILTER ELEMENT:
1. Remove the element from the POP-Charger aluminum venturi
and shake out any loose dirt.
2. Spray the element liberally with a water based cleaner like 409,
Simple Green, or laundry detergent mixed with warm water.
Basically any cleaner that could be used to remove grease from
a cotton tee shirt without damaging it.
3. Rinse the element with low pressure (IE. open ended garden
hose slightly opened) water from the inside outward.
4. Dry the element by shaking or swinging it to remove the
majority of water and allowing it to final dry naturally. No heat or
compressed air!
5. Spray an even coat of gauze air filter oil (most motorcycle,
performance shops or Jim Wolf Technology, inc.) lengthwise
along each pleat. Wait a few minutes and touch up any thin or
missed pleats.
6. Service intervals depend on the driving environment. Intervals
can be up to 50,000 miles or as short as one day for off-road
events. Generally the element can look pretty dirty and still be
working at a high efficiency since new particles continue to stick
to the previously trapped particles. If you are not sure, remove
the element and shine a light from the inside. If you can’t see
the light from the outside or it is dim, it’s time for service. Use
caution when cleaning or servicing car batteries located near
the filter, as battery acid residue will eat holes in the element.
I heard from performance centres that putting any oil based cleaner on the filter is bad idea.. and just use soapy water to clean it.
If its the cotton gauze type filter like K&N and JWT popcharger. Then they are pre-oiled already. when you clean them especially with detergents the oil needs to be re-applied. The K&N cleaning kit comes with the oil designed especially for the air filter.
I wouldnt recomend spraying oil onto the paper type that come standard with most cars.
I just bought some today mate
Pipercross from Halfords. There are two canisters, one cleaners filter, the other oils it after. £12.99
there you go! Im pretty sure its all the same stuff.
Guy in Halfords said they are identical (K&N and Pipercross) - both in stock both same price!
if u use the K and N it turns it red though not blue lol so take it pipercross will turn it green??? not cheap though is it!! you can by replacment elements also not sure on price maybe big phil or kev from envy could help!!!
?? the oil is clear and £12.99 every 50,000 miles is hardly expensive!
Oh yeah, that was me!!! Sorry mate :wacko:
ps Iv also now discovered I get about 10 to 20 less miles from a full tank with the pop charger fitted :(
That cos you drive faster to hear the popcharger :D
Fitted mine Sunday - piece of cake to fit providing you follow instructions - took less than an hour. Throttle a lot more responsive now and does seem quicker. Noticeable difference in noise at about 4k rpm - there is a real throaty RAW. I have noticed I am always changing gear at high revs now to hear it LOL so I guess my fuel consumption will drop as well!! :p
