Recommendations
Jehuty
I have a 2004 350 on 71k.. The clutch has just started slipping so time to replace.
I don't know much about clutches on z's.. What are you options on supplied clutch & flywheel packages? And will that be everything I need bar fitting?
Also what's the difference between duel mass & single mass? A friend of mine has recommended moving to single mass
