RS8055 Posted March 10, 2015 Share Posted March 10, 2015 Hi guys, Not sure which category to put this in, but all of a sudden the car has started to make this sort of squeaking/grinding noise which seems to be coming from somewhere near the front left wheel. Judging by the frequency of the noise slowing down and speeding up depending on speed, it must be something to do with the wheel or axle, but strangely enough, the squeak/grinding stops when the car is going roung a bend. It seems to be only when the wheels are straight. Has anybody else experienced this, and if so, could you please advise me of what this is? I have no warning lights on the dash. Cheers, Ryan Quote Link to comment Share on other sites More sharing options...
brillomaster Posted March 10, 2015 Share Posted March 10, 2015 first stop, check the wheel bearing... jack the car up, give the wheel a wiggle side to side and up and down - there should be no play. 1 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted March 10, 2015 Share Posted March 10, 2015 check the wear on the brake pads ! check the dust shield at the rear of the discs for stones or that they aren't bent wheel bearings usually drone and will make a noise when loaded i.e. cornering 2 Quote Link to comment Share on other sites More sharing options...
RS8055 Posted March 10, 2015 Author Share Posted March 10, 2015 Thing is, this all started after I was hooning it around the Brecon Beacons. It was a bit strange because the check engine light came on, but then went off again the next day and has remained off since then. I figured the mud might have gotten one of the sensors dirty or something. As I say, it's difficult for me to really explain the problem. There's no drone noise or anything, just this irritating squeaking noise when driving in a straight line! Also, the noise appears to stop whenever i am braking. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 10, 2015 Share Posted March 10, 2015 (edited) Metal dirt shield touching brake rotor, just bend it back to clear the rotor. Also check the worn brake pad warning device if fitted. Edited March 10, 2015 by ZMANALEX 1 Quote Link to comment Share on other sites More sharing options...
RS8055 Posted March 10, 2015 Author Share Posted March 10, 2015 On 10/03/2015 at 10:54, ZMANALEX said: Metal dirt shield touching brake rotor, just bend it back to clear the rotor. Also check the worn brake pad warning device if fitted. Thanks for the advice! I assume I will have to take the wheel off ideally to get at the dirt shield? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 10, 2015 Share Posted March 10, 2015 On 10/03/2015 at 11:12, RS8055 said: On 10/03/2015 at 10:54, ZMANALEX said: Metal dirt shield touching brake rotor, just bend it back to clear the rotor. Also check the worn brake pad warning device if fitted. Thanks for the advice! I assume I will have to take the wheel off ideally to get at the dirt shield? Correct: Wheel off to check the pads and dirt shield. 1 Quote Link to comment Share on other sites More sharing options...
philw99 Posted March 10, 2015 Share Posted March 10, 2015 I had this on mine, metal grinding noise coming from the front. I'd knocked the brake dirt shield and it was touching the back of the disc. Easy to spot on a ramp apparently Quote Link to comment Share on other sites More sharing options...
chrisday1990 Posted March 10, 2015 Share Posted March 10, 2015 On 10/03/2015 at 10:44, GIXXERUK said: check the wear on the brake pads ! check the dust shield at the rear of the discs for stones or that they aren't bent wheel bearings usually drone and will make a noise when loaded i.e. cornering I had to bend the dust shield away front the disc as it was making a grinding sound at low speeds 1 Quote Link to comment Share on other sites More sharing options...
Harryjax Posted March 11, 2015 Share Posted March 11, 2015 (edited) Check the bush on your lower control arm (banana bar) Had the same noise and the bush was totally knackered Got new bush from Ewen @ Clark motorsport. Keyser @ zed shed fitted as you need a 10ton press. Car feels better and noise gone. Edited March 11, 2015 by Harryjax Quote Link to comment Share on other sites More sharing options...
