steve916 Posted November 11, 2015 Share Posted November 11, 2015 Nice blockwork there by Andy....coming along nicely! The old bender and milling m/c remind me of apprentice days at ac delco many yrs ago. We still use those machines in our workshop at work Quote Link to comment Share on other sites More sharing options...
leonk Posted November 11, 2015 Share Posted November 11, 2015 Love the milling machine Chris. The metal folder would have been invaluable on the E type restoration. I bought a cheaper one that wasn't really up to the job and ended up using a friendly engineering companies. I think you will actually find it really useful. Just trying to think what I can send you to mill. 1 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted November 11, 2015 Share Posted November 11, 2015 Cool. You'll be able to mill regular donuts into the weird ring ones! 2 Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 12, 2015 Author Share Posted November 12, 2015 Cool. You'll be able to mill regular donuts into the weird ring ones! What a great idea Quote Link to comment Share on other sites More sharing options...
glrnet Posted November 12, 2015 Share Posted November 12, 2015 Cool. You'll be able to mill regular donuts into the weird ring ones! What a great idea Bollard might have something to say about that Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 12, 2015 Author Share Posted November 12, 2015 Well the big day we hoped for happened and everyone has still got all there fingers and toes attached Bit of background - the big steel was supposed to be lifted from the front garden to the back by an oversize crane (80 ton) this is not the weight but the reach, Crane company can't get it up the road so....... Small crane - nope they wanted more than a 100 Ton crane would have cost for a day and took to long to quote for the work, so we thought a telehandler would do the job, can't find one to rent in the south of England!!!! So we went back to a genie lift, we were a bit worried that it would not got high enough (5M needed) or lift the weight but we found 1 model is rated to lift 363KG at 5M so we hired one - We calculated the main beam to weigh 350 KG so inside the limit if only just, but you try dangling a 5.6M wide steel beam that weighs 350KG above your head on an aluminum bar that bends like a fishing rod while popping and twanging like it's about to break, then try and push it out of line around the wall and back in again - bum twitching moments all round!!!! But we did it The other 2 bars went up relatively easy after that A load of timber and the chippy Scott arrived early this morning so hopefully have some framework up by the end of the week Hats off to Andy for not losing his nerve when he had the task of lining up the beam and sticking the first bolt in More soon Keyser and The Zed Shed Crew. 5 Quote Link to comment Share on other sites More sharing options...
glrnet Posted November 12, 2015 Share Posted November 12, 2015 Hats off to you but only confirms you are bonkers, totally bonkers!! :lol: 1 Quote Link to comment Share on other sites More sharing options...
gsexr Posted November 12, 2015 Share Posted November 12, 2015 Keep it coming. Great to see this evolving 1 Quote Link to comment Share on other sites More sharing options...
glrnet Posted November 12, 2015 Share Posted November 12, 2015 Andy has claerly developed an adrenalin dependency since he took his Zed "flying" 3 Quote Link to comment Share on other sites More sharing options...
davedutch Posted November 12, 2015 Share Posted November 12, 2015 Hats off to you but only confirms you are bonkers, totally bonkers!! :lol: Graham, I'm not sure bonkers accurately describes any of them - insane would be more accurate. But some outstanding work regardless. 1 Quote Link to comment Share on other sites More sharing options...
andy james Posted November 12, 2015 Share Posted November 12, 2015 Well the big day we hoped for happened and everyone has still got all there fingers and toes attached Bit of background - the big steel was supposed to be lifted from the front garden to the back by an oversize crane (80 ton) this is not the weight but the reach, Crane company can't get it up the road so....... Small crane - nope they wanted more than a 100 Ton crane would have cost for a day and took to long to quote for the work, so we thought a telehandler would do the job, can't find one to rent in the south of England!!!! So we went back to a genie lift, we were a bit worried that it would not got high enough (5M needed) or lift the weight but we found 1 model is rated to lift 363KG at 5M so we hired one - We calculated the main beam to weigh 350 KG so inside the limit if only just, but you try dangling a 5.6M wide steel beam that weighs 350KG above your head on an aluminum bar that bends like a fishing rod while popping and twanging like it's about to break, then try and push it out of line around the wall and back in again - bum twitching moments all round!!!! But we did it The other 2 bars went up relatively easy after that A load of timber and the chippy Scott arrived early this morning so hopefully have some framework up by the end of the week Hats off to Andy for not losing his nerve when he had the task of lining up the beam and sticking the first bolt in More soon Keyser and The Zed Shed Crew. After the awful weather of last week the pressure was still on to sort out a way of lifting up the steel beams. I have used genies before with standard RSJs but not at anywhere near this height,weight and awkward shape so even after 30 years experience Mr James,Chris and Kim were in a serious bum twitching situation!! Lol. Bloody amazing piece of kit,and as Chris said to me you have to trust the fact that it will lift what it says on the label! Lol We done good yesterday and are on the home straight now. Quote Link to comment Share on other sites More sharing options...
glrnet Posted November 12, 2015 Share Posted November 12, 2015 Hats off to you but only confirms you are bonkers, totally bonkers!! :lol: Graham, I'm not sure bonkers accurately describes any of them - insane would be more accurate. But some outstanding work regardless. I was being polite for once Dave Quote Link to comment Share on other sites More sharing options...
Humpy Posted November 12, 2015 Share Posted November 12, 2015 Good effort! Quote Link to comment Share on other sites More sharing options...
neo Posted November 13, 2015 Share Posted November 13, 2015 Coming along very nicely Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 25, 2015 Author Share Posted November 25, 2015 (edited) so just to keep you up to speed a couple of pics of the progress Start of the wood work and moving on that was the end of last week I'll get some more tomorrow. Just so you know I haven't been slacking they gave me the good job putting the nails in theses 22 nails in each and over 100 of them Still it all needs to be done more soon ............................. Edited November 25, 2015 by Keyser 5 Quote Link to comment Share on other sites More sharing options...
ioneabee Posted November 25, 2015 Share Posted November 25, 2015 I love a good truss clip 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 25, 2015 Author Share Posted November 25, 2015 In other news I have started on the milling machine, a strip down and clean Got this to start lots to clean Bit of rewiring as the motor drive is not working properly and the over-ride button sticks in More to follow 2 Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted November 25, 2015 Share Posted November 25, 2015 Just so you know I haven't been slacking they gave me the good job putting the nails in theses 22 nails in each and over 100 of them They don't trust you with one of these then . . . 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 25, 2015 Author Share Posted November 25, 2015 I'm not allowed near power tools 3 Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 25, 2015 Share Posted November 25, 2015 Looking GRAND Chris, looks like the skies have been favourable. If the weather stays reasonable how soon till the roof is complete with tiles? Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted November 25, 2015 Share Posted November 25, 2015 God I'm regretting subbing to this thread with instant email updates yesterday Looking great though! The progress has been rapid once red tape is out of the way. Quote Link to comment Share on other sites More sharing options...
veilside z Posted November 26, 2015 Share Posted November 26, 2015 The old Bridgeport milling machine, that bring back memories. The build is coming along nicely Chris, is this new build the the old Z shed renovated or a completely new construction? Also who's garden is this being constructed in. B) Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted November 26, 2015 Share Posted November 26, 2015 Looks awesome when can we move in lol? Quote Link to comment Share on other sites More sharing options...
Stutopia Posted November 26, 2015 Share Posted November 26, 2015 Just so you know I haven't been slacking they gave me the good job putting the nails in theses 22 nails in each and over 100 of them They don't trust you with one of these then . . . Can you imagine the horror?!? Poor Zed Shed visitors having to remove one of those nails from a buttock with a claw hammer Quote Link to comment Share on other sites More sharing options...
mattross1313 Posted November 26, 2015 Share Posted November 26, 2015 You had half the roof up when I visited ages ago!! What you been doing all this time?? Quote Link to comment Share on other sites More sharing options...
