overheating
snoged
good evening
while sitting in traffic today temp gauge went into the red and steam from under the bonnet,left in parked for a couple of hours then got it home,all ok while moving probably because its so cold today,just had a quick look again left it running on the drive once again temp goes right up and the heater in side the car only gets luke warm would this be an air lock ? the other thing i noticed is that the radiator fans do not come on
any advice is more than welcome
Due to it overheating there is a good chance its airlocked. I would recommend not driving it at all as there may be zero cooling/coolant within certain parts of the block. Time to get the fans out and refurb the motors (or replace) also need to get replacement fluid for it.
cheers for the quick replys
ill check with the aircon on in the morning
seems odd both motors to fail at the same time is this that common ? its dome 60000 miles
Yes as Ricky said it is a very common fault unfortunately. Been lot's of threads about this...
http://www.350z-uk.com/topic/70988-radiator-fans-not-working-properlyoverheating/
http://www.350z-uk.com/topic/59782-overheating-fans-ac-not-working/
http://www.350z-uk.com/topic/39929-radiator-fan-problem-heating/
http://www.350z-uk.com/topic/49013-radiator-fan-replacement-outside-of-warranty/
Radiator fan fix guide: http://www.350z-uk.com/topic/88321-carried-out-a-rad-fan-motor-fix-today-small-how-too/
Radiator fan fix guide video: http://www.350z-uk.com/topic/69810-how-to-repairfix-your-cooling-fan-motors-youtube-vid/
The most popular solution is the Mishimoto upgrade fan kit: http://www.350z-uk.com/topic/87662-mishimoto-replacement-fan-kit-350z-vq35de/
:thumbs:
If your facing the car from the front, at the back left of the plenum you will see a rubber pipe which has a plastic section on it with a philips (star) head on it. Remove that carefully and air it from there. You may have to do some pipe squeezing to force the air out and through the system etc.
looks like its all ok now
would love to know what caused this to happen in the first place !
Thanks so much to all who replied to my post, great help/advice and probably saved me a few quid
Cheers !
Could be that the fans are on their way out, ...keep an eye on the temperature level when driving just in case it happens again.
Hopefully it won't though and all will be good. :thumbs:
right must be the fans got pretty hot today while in traffic had a look this evening fans are turning but very slowly
had a look on here for the correct way of getting them off has anyone any tips for this who may have done the job before ?
Not done it myself but some info in here: http://www.350z-uk.com/topic/88848-removal-of-radiator-cooling-fans-without-removing-the-radiator/
Also maybe worth sending a PM to the OP in the link I provided you with (post number 7) regarding the fan motor repair to see if they can give you any help. :thumbs:
thanks for that thread looks like Alex knows his stuff thats the route ill take
just one more question best place to buy the replacements ?
You going for standard fans?
You could PM zmanalex for good quality used working fan motors (cheapest option) or get new OEM fan motors from Clark Motorsport or get what most people do which is the Mishimoto fan shroud kit (cheaper than OEM & a good upgrade) also available from Clark Motorsport as well as a few other traders on here.
Link: http://www.350z-uk.com/topic/87662-mishimoto-replacement-fan-kit-350z-vq35de/
:thumbs:
just thought i would write a few lines on what iv'e done
fitted the Mishimoto fan shroud kit today took about 45 mins to get the oem one out and about 15-20 to put the replacement in,system bled and all works fine :) new fans are quite loud though !
Must give a mention to Clark Motorsport namely Ewen,really helpful and a very fast delivery and well packed thanks !
That's great snoged. :)
One thing worth checking as I have heard of people getting this wrong before is to make sure the fans are going the right way. E.g. Drawing cold air through the radiator rather than the opposite.
Hopefully yours is wired up correctly and this is the end to your overheating problems. :thumbs:
