Marti350z Posted February 24, 2015 Share Posted February 24, 2015 Just received nine today, now I received the unit itself and the lead which is suppose to be specific to the Z.. Now this lead doesnt fit my car, it fits into the pedal plug but not the other part, can anybody confirm if this is the wrong/right lead as the company I bought it off swear blind it's the right one.. Cheers Quote Link to comment Share on other sites More sharing options...
Marti350z Posted February 24, 2015 Author Share Posted February 24, 2015 So it just got very serious, just went to drive my car, and nothing car won't start, tried to plug the diagnostic machine in and there's no power to the port.. With the ignition on if I press the throttle I can't hear anything, should I be able too? Quote Link to comment Share on other sites More sharing options...
alanm Posted February 24, 2015 Share Posted February 24, 2015 (edited) Hi, had the same issue with mine when i bought it. Its the lead with the white bit sticking out that doesn,t plug in isn,t it. Tried for ages to get it to fit. In the end i attacked the plug and yanked out the white cradle ( the bit sticking out of the plug ) fitted a treat after that. Edited February 24, 2015 by alanm Quote Link to comment Share on other sites More sharing options...
Marti350z Posted February 24, 2015 Author Share Posted February 24, 2015 Well I will give that a go I think, did it come straight out in one piece? I need to get the car running again first Quote Link to comment Share on other sites More sharing options...
Pinoy-R Posted February 24, 2015 Share Posted February 24, 2015 (edited) I had the same problem, till I realised you need to remove the white bit, you'll need to do a ecu reset, if the engine warning light is on, there's a guide on here and on the net how to do it. Just be patient it's all about timing, good luck! Edited February 24, 2015 by Pinoy-R Quote Link to comment Share on other sites More sharing options...
