need a new key.
radjordan
If you don't mind a refurbished key, I got mine here http://m.ebay.co.uk/itm/111596643946?_mwBanner=1
But you'll need to
1) get your local locksmiths to cut the blade for you
2) program the lock/unlock button yourself (Guide here http://www.350z-uk.com/index.php?showtopic=16896)
3) Go to Nissan to get the immobiliser programmed (check how much they charge for this only, else some locksmiths can do this too)
Sounds like a mission but should cost less than £250.
Check out my build thread, final post about my new key.
I had a new one supplied and programmed by The Auto Key Squad a couple of weeks ago for £219.
Cutting the key and programming the remote lock/unlock was easy but it took the techie a while to resolve the immobiliser code. He got it eventually by using the bar code details that are on top of the steering column under the plastic shroud.
David
