Richy Posted February 22, 2015 Share Posted February 22, 2015 I have a warning light showing which I can not find in the manual. It is a yellow one, and looks like a horse shoe with a flat slightly jagged bottom, and a warning exclamation mark inside. It is at the bottom of the cluster of lights that come on when the engine is started, and stays on when the rest go out. Any ideas ? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 22, 2015 Share Posted February 22, 2015 Flat Tyre. Quote Link to comment Share on other sites More sharing options...
Richy Posted February 22, 2015 Author Share Posted February 22, 2015 Tyres seem fine, so I assume it is a slight lose of pressure in one. Does the warning system identify which one is low ? Nothing in the manual that I can find. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
ioneabee Posted February 22, 2015 Share Posted February 22, 2015 I think..... it shows when there is a measurable differential of pressure from 1 minute to the next (times are guestimates) - I don't "think" it shows if it goes down slowly Quote Link to comment Share on other sites More sharing options...
flyboy Posted February 22, 2015 Share Posted February 22, 2015 Didn't know we had tpms on the 370 is it an option or std? Quote Link to comment Share on other sites More sharing options...
ioneabee Posted February 22, 2015 Share Posted February 22, 2015 thought it was standard - but mine is the GT Edition, so there weren't any extras available and its definately on that when you next change your rubbers - its a little grey box fixed next to the air adder thingy Quote Link to comment Share on other sites More sharing options...
Richy Posted February 22, 2015 Author Share Posted February 22, 2015 My manual doesn't mention this warning light, so perhaps it is a recent addition, but manual hasn't been updated. Quote Link to comment Share on other sites More sharing options...
flyboy Posted February 22, 2015 Share Posted February 22, 2015 Nothing inside my tyres but air. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 22, 2015 Share Posted February 22, 2015 Tyres seem fine, so I assume it is a slight lose of pressure in one. Does the warning system identify which one is low ? Nothing in the manual that I can find. Thanks for your help. Just check the pressures in all 4 and inflate to correct pressure. Report back if this does not fix your issue. 2 Quote Link to comment Share on other sites More sharing options...
Ebized Posted February 22, 2015 Share Posted February 22, 2015 Some info here: http://www.the370z.com/wheels-tires/10233-how-do-i-reset-tpms.html Pretty sure the tpms was introduced with the Connect Premium models as it certainly was not on my 2009 370z. If you have metal valves as opposed to the usual rubber variety I believe that is the way of telling - its what I have on the A45. 1 Quote Link to comment Share on other sites More sharing options...
Marcus01 Posted February 22, 2015 Share Posted February 22, 2015 Its not on 2010 models, pretty sure 2011 onwards only. Quote Link to comment Share on other sites More sharing options...
Richy Posted February 22, 2015 Author Share Posted February 22, 2015 Problem solved. Pressure was down in all four tyres. Thanks for the help, and I think Nissan should up date their manual. Mine is dated 2010. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 22, 2015 Share Posted February 22, 2015 Why do you require an updated manual when you have this forum? Quote Link to comment Share on other sites More sharing options...
Richy Posted February 22, 2015 Author Share Posted February 22, 2015 Why do you require an updated manual when you have this forum? True, but I wouldn't have looked quite so stupid. 1 Quote Link to comment Share on other sites More sharing options...
