Davectr Posted February 22, 2015 Share Posted February 22, 2015 If I disconnect the battery for a few weeks will it throw up any errors when I reconnect it? I'm thinking of having the steering wheel re-trimmed but I'm wary of having battery off for so long 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 22, 2015 Share Posted February 22, 2015 Having the battery disconnected should not throw up any codes, however remember and lock your steering if you are removing the steering wheel. Quote Link to comment Share on other sites More sharing options...
Davectr Posted February 22, 2015 Author Share Posted February 22, 2015 Cheers Alex Quote Link to comment Share on other sites More sharing options...
Bems Posted February 22, 2015 Share Posted February 22, 2015 I'll let you know in an hour or two Dave Quote Link to comment Share on other sites More sharing options...
Davectr Posted February 22, 2015 Author Share Posted February 22, 2015 Aaargh! Took the outer security screw out, went to do the inside one (nearest to the stereo) and it started to round off with hardly any force on it. Any suggestions other than drilling it out? Quote Link to comment Share on other sites More sharing options...
Ebized Posted February 22, 2015 Share Posted February 22, 2015 Impact driver if there is room - will kill the screw head completely but might at least get it out. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 22, 2015 Share Posted February 22, 2015 Aaargh! Took the outer security screw out, went to do the inside one (nearest to the stereo) and it started to round off with hardly any force on it. Any suggestions other than drilling it out? Use the proper fitting tools in the first place. Now you will have to try a slightly larger size, give it a slight tap with a hammer so that it is good tight fit and bobs your uncle. Quote Link to comment Share on other sites More sharing options...
Davectr Posted February 22, 2015 Author Share Posted February 22, 2015 Aaargh! Took the outer security screw out, went to do the inside one (nearest to the stereo) and it started to round off with hardly any force on it. Any suggestions other than drilling it out? Use the proper fitting tools in the first place. Now you will have to try a slightly larger size, give it a slight tap with a hammer so that it is good tight fit and bobs your uncle. Ha ha, thanks for that 😉 Gonna have to give that a go tomorrow , can't beat using a big hammer! 😄 Quote Link to comment Share on other sites More sharing options...
