Morel Mids : DLS Passive Xovers : 350z Door speaker rings
notfub
I am selling my Morel Dotec Ovation 6.5†Midrange speakers plus birch ply mounting rings for 350z front doors. The rings were mounted to the door frame using three small screws, with the rings being covered in dynaliner foam to stop vibrations and keep moisture out. I will also include my used skinz moisture guards which were also used in the install (these are material shrouds fitted over the back of the speaker to shield it from any debris inside the door cavity).
These midrange speakers were supplied and installed into my 350z by professional in car entertainment specialists, Sonic Frontiers (http://www.sonicfrontiers.co.uk/1377/nissan-350z-from-oem-bose-to-superior-sonic-punch/).
Lee from Sonic Frontiers also used Morel MT-23 tweeters in custom built a-pillars (see separate for sale advert) and DLS Reference R6A Passive Crossovers, “to get the best crossover slope and setting for the 350z’s acousticsâ€) to provide a custom front end listening experience that did not disappoint in clarity, detail, slam and staging, placing vocals separately and clearly at the driving position.
Morel Doctec Ovation Details
Featuring some of Morel's best technological innovations, the Dotech Ovation series delivers quality, performance, and affordability in one compact stylish system. Dotech Ovation holds great appeal for car audio lovers looking for powerful sound and exceptional value. Dotech represents a sound investment for music lovers.
Dotech Ovation features Morel's Unified one-piece chassis with shallow aerodynamic design to reduce sound reflection distortion and mounting depth. Dotech's double magnet drive motor and its large 54mm (2 1/8â€) diameter Hexatechâ„¢ aluminum voice coil, provides better cone support and higher power handling. The use of Morel's C.A.R. Filter technology improves acoustical loading and enhances the woofer's ability to perform well in free-air environments
Morel Specs
Nominal Impedance : 4 Ohm
Power Handling : 140W
Max. Transient Power Handling : 500W
Sensitivity (2.83V/1M) : 90dB
Frequency Response : 40-22000Hz
Voice Coil Diameter : 54mm (2.1")
Voice Coil Wire : Hexatechâ„¢ Aluminum
Magnet System : Double ferrite rear vented
Mounting Depth : 61mm (2.4")
PICTURES
PRICES
Morel Dotec Ovation 6.5†midbass speakers (pair) inc 350z mounting rings = £125 delivered
DLS Reference R6A Passive Crossovers = £40 delivered
Birch ply rings = £15 delivered
Combined for Morel's DLS over and rings = £150 delivered
