MrBlack Posted February 17, 2015 Share Posted February 17, 2015 Hey all took my headlights out as i am going to try and clean them and replace bulbs just checking is this the pin change that was needed for uk swap ? i think this is the bit that has been cut then the bulb was connected to the red/black connector ? then this one is rendered useless : Also ever noticed this before anyone on here name Toyboy Any help appreciated also anyone got any links to bulbs i can purchase that are brighter ? White lights? Thanks car currently sits as this Quote Link to comment Share on other sites More sharing options...
MrBlack Posted February 17, 2015 Author Share Posted February 17, 2015 Left is bulbs i purchased right is one i removed long story short should i just order high beam H4 bulbs ? Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted February 17, 2015 Share Posted February 17, 2015 As I've recently swapped headlights from single xenon to bi xenon on my UK car I can try to help though I suspect anyone who has done the JDM to UK swap is what you really need! Yes to your first question. But from there on everything doesn't really add up. From what you are saying and the pics it would appear that the pin switch has been performed but your xenon bulb has been disabled and replaced with an H4 halogen bulb. The swap should have converted the non- xenon halogen set up on the base JDM or USDM spec car to a single xenon UK spec car. So I suspect the conversion was not welldone. The single xenon have D2R main buib and H7 high beam bulb. The bi xenon have just a single D2R bulb that flicks between main and high beam with the operation of a shutter. Quote Link to comment Share on other sites More sharing options...
MrBlack Posted February 17, 2015 Author Share Posted February 17, 2015 Ah ok thanks for the help . do you think i should keep this setup and just get h4 halogen bulbs ? is this my best option Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted February 17, 2015 Share Posted February 17, 2015 It's really pointless to have a xenon set up and downgrade it to a halogen set up which is inferior. I think you should hang in there and find someone who has done this here or go to a proper auto electrician and get this done properly. Someone will come along soon enough. Quote Link to comment Share on other sites More sharing options...
MrBlack Posted February 17, 2015 Author Share Posted February 17, 2015 Ok buddy , ill wait about , i have the normal halogen for now which was what it was for now , and maybe try and find more info Quote Link to comment Share on other sites More sharing options...
