RobPhoboS Posted February 15, 2015 Share Posted February 15, 2015 (edited) Hey guys I installed my new suspension yesterday, all parts are torqued as per the manual. I thought it could be the top mount but it's tight and seems good, as well as the suspension piston rod nuts. I don't have the cat exhaust shields, and tried without the strut tower bar. For the last couple of weeks I had the rattling after installing new springs. It was far louder and i assumed that it was the broken front left top mount (2 nuts were broken, so not holding properly). So it leads me to assume it's the compression arm again but they were changed on 20th April 2013. Just seems odd that the noise has only just started when I've changed the suspension (with another top mount). It's a similar noise as before just not as loud. I thought they would last a bit longer than that. I'll try to get an audio clip up. Edited February 15, 2015 by RobPhoboS Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted February 15, 2015 Share Posted February 15, 2015 Drop links ? Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted February 15, 2015 Author Share Posted February 15, 2015 I'll check them, they seemed ok to me, not split. I'll do a search for how to check them. Cheers Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted February 15, 2015 Author Share Posted February 15, 2015 (edited) Right, I did the left foot on the brake whilst going over some cobbled surface. The noise stops when I did that. Which points me to the compression arm. However, now I have to figure out if it's the ball joint or the bushing, if it's the bushings no problemo as I have a couple of poly sets to try out (as it's currently the stock rubber one). Edited February 15, 2015 by RobPhoboS Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted February 17, 2015 Share Posted February 17, 2015 How did you get on with this rob? How are the bilsteins? Quote Link to comment Share on other sites More sharing options...
