From Hero to Zero <1mile
Daryl
About 450 for the 4 dampers ........
I really can't use anything lower than what I have already ( Round 20mm drop) and with only a little drop I'm still able to adjust the camber using the oem equipment . Ya hopefully it should be good , as the teins are pretty much the same rates as standard and the bilsteins b6 are ment for standard springs or up to 30mm lowered ..... We shall see!!
Be interested in seeing what you think of that set up, sounds like a good route, will save you money over coilovers too. Only thing will be that you wont be able to adjust them if you wanted to do a track day or anything like that. But if your not bothered then thats fine.
