Adrian@TORQEN Posted February 9, 2015 Share Posted February 9, 2015 (edited) 1. 350z DE AAM Competition 2.5" High Flow Cats The AAM Spec 2.5" High Flow Cat Pipes for the Nissan 350Z and Infiniti G35 are the ultimate high-flow cats available for the 350Z & G35. Constructed out of robust 2.5? mandrel bent 16-gauge T-304 stainless steel to ensure the highest quality and reliability, the AAM Spec 2.5" High Flow Cat Pipes replace your vehicles restrictive factory catalytic converter with a new technology in high-flow converter element. The new metallic converter technology flows 40% more than most other cats currently on the market. This allows a significant gain in flow which makes the AAM Spec 2.5" High Flow Cat Pipes a perfect fit for both naturally aspirated and supercharged/turbocharged 350Z & G35. Dyno testing has shown 8+ rwhp gains on a near stock Nissan 350Z and 15+ rwhp gains on a turbocharged Infiniti G35! Factory Cats: approx 26 lbs AAM Spec 2.5" High Flow Cats: approx 12 lbs Weight savings: 14 lbs £399 2. 350z HR AAM Competition 2.5" High Flow Cats The AAM Spec 2.5" MaxFlow Cat Pipes for the Nissan 350Z 07+ are the ultimate high-flow cats available for the 350Z 07+. Constructed out of robust 2.5? mandrel bent 16-gauge T-304 stainless steel to ensure the highest quality and reliability, the AAM Spec 2.5" MaxFlow Cat Pipes replace your vehicles restrictive factory catalytic converter with a new technology in high-flow converter element. The new metallic converter technology flows 40% more than most other cats currently on the market. This allows a significant gain in flow which makes the AAM Spec 2.5" MaxFlow Cat Pipes a perfect fit for both naturally aspirated and supercharged/turbocharged 350Z & G35. Dyno testing has shown 8+ rwhp gains on a near stock Nissan 350Z and 15+ rwhp gains on a turbocharged 350Z! Factory Cats: approx 26 lbs AAM Spec 2.5" MaxFlow Cats: approx 12 lbs £439 3. 350z DE AAM Competition 2.5" Test Pipes The highly anticipated AAM Spec 2.5" Test Pipes for the Nissan 350Z and Infiniti G35 are finally here! After servicing and installing several of our competitors designs we decided to make a higher-quality test pipe that meets the demanding reliabilty expectations of our customers. In addition to having poor fittment, many of the test-pipes on the market are constructed of thinner, lower grade stainless tubing. Not only are these units highly succeptable to fatigue and cracking on near stock 350Z's and G35's, some customers with supercharged and turbocharged 350Z's have torn apart the weld joints of these inferior test-pipes. Made out of 2.5" mandrel bent 16-gauge 304 stainless steel to ensure the hightest reliability and quality, the AAM Spec 2.5" Test Pipes replace your vehicles restrictive units to allow the higest possible exhaust flow. Dyno testing has shown 8 to 10 RWHP gains on a near stock Nissan 350Z and 20+hp gains on a turbocharged Nissan 350Z! The AAM Spec 2.5" Test Pipes are for off-road use only and are a direct bolt-on replacement of the factory units. £199 4. 350z HR AAM Competition 2.5" Test Pipes The highly anticipated AAM Comp 2.5" Test Pipes for the 2007 Nissan 350Z are finally here! After servicing and installing several of our competitors designs we decided to make a higher-quality test pipe that meets the demanding reliabilty expectations of our customers. In addition to having poor fittment, many of the test-pipes on the market are constructed of thinner, lower grade stainless tubing. Not only are these units highly succeptable to fatigue and cracking on near stock 350Z's and G35's, some customers with supercharged and turbocharged 350Z's have torn apart the weld joints of these inferior test-pipes. Made out of 2.5" mandrel bent 16-gauge 304 stainless steel to ensure the hightest reliability and quality, the AAM Spec 2.5" Test Pipes replace your vehicles restrictive units to allow the higest possible exhaust flow. Dyno testing has shown 8 to 10 RWHP gains on a near stock 2007 Nissan 350Z! The AAM Spec 2.5" Test Pipes are for off-road use only and are a direct bolt-on replacement of the factory units. Weight savings: 11 lbs £249 5. 350z AAM Competition Stainless Steel Y-Pipe Constructed of 16-gauge T-304 Stainless Steel to ensure the highest reliability, quality, and performance, AAM is proud to announce the release of its Y-Pipe for the Nissan 350Z and Infiniti G35. Using smooth 2.5" mandrel bent tubing and stainless steel flex joints which flow into one large 3" tube, the AAM Spec Y-Pipe improves upon the factory Y-Pipe's restrictive design by allowing a substantial increase in the mass of exhaust flow, and reduces the backpressure and thermal stress, which helps to unleash the engine's potential for increased power and torque. Dyno tested on a near stock 2004 Nissan 350Z, the AAM Spec Y-Pipe gained 8 RWHP in comparison to the factory Y-Pipe! Don't be fooled by competitors designs which commonly use 18 or 20-gauge tubing that is prone to cracking, and non-stainless steel (if any) flex sections. The AAM Spec Y-Pipe is a direct bolt-on upgrade that requires no modification of any factory components. £329 6. 350z DE AAM Competition Resonated Test Pipes Objectives behind the design of AAM Competition Resonated Test Pipes are simple; increase exhaust flow, enhance exhaust note, while minimize drone and rasp. It is not uncommon to develop drone and rasp while freeing up the exhaust flow of your Nissan/Infiniti. Although AAM Competition Resonated Test Pipes will not guarantee a complete drone/rasp free set up, we can assure that the additional resonator in the test pipes will combat odd exhaust frequencies that cause drone/rasp. The factory catalytic converter leaves a lot of power on the table with its smaller piping diameter and extremely dense core. While being a very simple and inexpensive bolt on, upgrading to aftermarket test pipes is a no-brainer. AAM Competition 2.5? Resonated Test Pipes replace the factory catalytic converter and are designed purely for off-road performance. Each unit is hand assembled at AAM Competition's manufacturing facility in the U.S.A., using raw T-304 16 gauge stainless steel piping with T-304 stainless steel flanges. £399 7. 350z DE Berk Technology Metallic Substrate High Flow Cat Metallic substrate HFC's. Spun catalytic converters, full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Made in the USA. £389 8. 350z HR Berk Technology Metallic Substrate High Flow Cat Metallic substrate HFC's. Spun catalytic converters, full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Made in the USA. Includes our custom made soft crush graphite collector gaskets for a leak free seal. These are made specifically for the new HR motor by BERK. Made with pride in the USA. £419 9. 350z DE Berk Technology Test Pipes Dual 60mm Test Pipes w/ Built in O2 CEL fix. Additional O2 Bung Included on both pipes for left bank & right bank wide band O2 fuel tuning. Full 304SS. Built in CEL fix is ~95% effective in most cases. Your results may vary. £179 10. 350z DE CNT Racing High Flow Catalytic Converters CNT Racing Nissan 350Z High Flow Catted Pipes. Made with T-304 Stainless steel, 0.5inch flange. Come with two 200 cell metallic High flow Cat. Extended 02 sensor bung is weld for Check engine light fix. Extra 02 sensor bung for wideband. (02 sensor cap included if not needed). £339 11. 350z HR CNT Racing High Flow Catalytic Converters CNT Racing Nissan 350Z HR High Flow Catted Pipes. Made with T-304 Stainless steel, .5inch flange. Come with two 200 cell metallic High flow Cat. Extended 02 sensor bung is weld for Check engine light fix. Extra 02 sensor bung for wideband. (02 sensor cap included if not needed). £349 12. 350z HR CNT Racing Resonated Testpipe Great Alternative to Raspy Testpipes, yet still produce more power then HFCs. Made with T-304 Stainless steel, extra 02 sensor bung for wideband, longer extended 02 bung for cel fix. Comes with bolts and gasket and support bracket. £199 13. 350z DE Invidia 60mm Test Pipes Invidia produces high performance parts for today?s hottest tuner cars. Invidia knows that automotive enthusiasts are constantly looking for ways to extract more power from their engines and improve the driving experience. Using only the highest quality materials Invidia manufactures components that improve performance while remaining stylish. Invidia manufactures their exhaust systems specifically for each application to guarantee precise fitment and power gains. Invidia has applied their knowledge of automotive performance to a myriad of makes and models constantly refining and improving their product and design process. Invidia offers several exhaust system product lines to meet the expectations of nearly any automotive enthusiast. Invidia test pipes are constructed for the serious automotive enthusiast. The factory catalytic converter is basically a screen that heats up to burn off excess fuel. This screen also slows down exhaust flow, chokes off your engine, and reduces noise. Replacing the factory unit with Invidia?s test pipe is yet another important step toward maximizing exhaust flow and performance. Invidia?s test pipe replaces the factory unit with free flowing, strait through unrestricted pipe to completely maximize performance. £199 14. 350z DE Invidia Test Pipes To complement the line of Invidia Exhaust Systems, Invidia offers the final piece of the puzzle with Invidia Test Pipes. Manufactured from SUS304 Stainless Steel, these Invidia Test Pipes will replace your stock catalytic converter and unleash the power in your car. £189 15. 350z HR Invidia High Flow Catalytic Converter Invidia produces high performance parts for today?s hottest tuner cars. Invidia knows that automotive enthusiasts are constantly looking for ways to extract more power from their engines and improve the driving experience. Using only the highest quality materials Invidia manufactures components that improve performance while remaining stylish. Invidia manufactures their exhaust systems specifically for each application to guarantee precise fitment and power gains. Invidia has applied their knowledge of automotive performance to a myriad of makes and models constantly refining and improving their product and design process. Invidia offers several exhaust system product lines to meet the expectations of nearly any automotive enthusiast. Invidia high flow cats are constructed for the serious automotive enthusiast. The factory catalytic converter is basically a screen that heats up to burn off excess fuel. This screen also slows down exhaust flow, chokes off your engine, and reduces noise. Replacing the factory unit with Invidia?s high flow cat is yet another important step toward maximizing exhaust flow and performance. Invidia?s high flow cat replaces the factory unit with freeer flowing unit to increase exhaust flow and offer a more raw sound. The high flow cat is perfect for drivers who seek an exhaust note that is slightly less extreme than a catless exhaust system. The best feature of a high flow cat is it offers more horsepower and torque than the factory cat while retaining the driveability of a catted exhaust system. Features: Pipe Diam.: 60 mm Stainless steel construction Freer flowing design to increase exhaust flow Increases horsepower and torque £429 16. 350z DE Kinetix Racing High Flow Cats New and Improved with more installation clearance and long term strength. The factory catalytic converters are well known as the biggest "choke point" in the factory exhaust system. These high flow CARSOUND/MAGNAFLOW catalytic converters blow away the stock converter flow rates while still maintaining legal emissions levels. Constructed with stainless tubing and 3/8" stainless flanges (converters are aluminized steel). Fully TIG welded and true mandrel bends used throughout. The CARSOUND converters are widely known as some of the best and are also marketed under the MAGNAFLOW brand name. These converters will bolt up to any header (factory or aftermarket) and any exhaust (factory or aftermarket). These pipes also retain the factory Oxygen sensor location and WILL NOT THROW A CHECK ENGINE LIGHT!!. Expect great performance gains from these converters as they have dyno'd between 5-8 hp at the wheels on factory 350Z's. They only add a slightly more aggressive exhaust note and do not have the pesky "raspiness" between 3-4k rpm that is seen with straight through test pipes. All of our pipes come complete with bolts, washers, and lock nuts. £349 17. 350z HR Kinetix Racing High Flow Cats New and Improved with more installation clearance and long term strength. The factory catalytic converters are well known as the biggest "choke point" in the factory exhaust system. These high flow CARSOUND/MAGNAFLOW catalytic converters blow away the stock converter flow rates while still maintaining legal emissions levels. Constructed with stainless tubing and 3/8" stainless flanges (converters are aluminized steel). Fully TIG welded and true mandrel bends used throughout. The CARSOUND converters are widely known as some of the best and are also marketed under the MAGNAFLOW brand name. These converters will bolt up to any header (factory or aftermarket) and any exhaust (factory or aftermarket). These pipes also retain the factory Oxygen sensor location and WILL NOT THROW A CHECK ENGINE LIGHT!!. Expect great performance gains from these converters as they have dyno'd between 5-8 hp at the wheels on factory 350Z's. They only add a slightly more aggressive exhaust note and do not have the pesky "raspiness" between 3-4k rpm that is seen with straight through test pipes. All of our pipes come complete with bolts, washers, and lock nuts. £369 18. 350z DE Kinetix Racing Resonated Test Pipe These pipes replace your factory catalytic converters, letting all the exhaust pass through freely, but not the noise. Plain test pipes offer the highest level of flow, but often result in a "raspy" exhaust note between 3-4k rpm. Test pipes have always been high on the "bang for the buck" list, but the louder exhaust ote can be too aggressive for some people. So we now offer a full stainless straight through converter replacement, but with a stainless exhaust resonator welded in-line. This gives an equal amount of flow, but without the raspiness. The exhaust note will only be slightly louder, and have a slightly deeper tone. Catalytic converters are the biggest "choke" point in the exhaust. These pipes have shown a 5-10hp increase at the wheels on factory 350z's. Our CARB legal converters will show almost equal gains, but straight throughs are a MUST for any FI application. On Turbocharged cars (example Greddy) we consistently see gains of 25-35 hp !! with faster spool times. Constructed entirely of S.S. and feature true mandrel bends and 3/8" thick flanges with a highly polished 4" body full stainless resonator on each pipe. They also feature factory located O2 oxygen sensor bungs so factory sensors are retained. These will NOT THROW A CHECK ENGINE LIGHT after installation. They will bolt right up to either factory headers or aftermarket headers. They are also compatible with either factory or aftermarket exhausts. They also retain the factory converter "brace" (not shown in picture) All of our converters come with new hardware including bolts, washers, and lock nuts. £339 19. 350z Kinetix Racing Test Pipes These pipes completely remove your factory catalytic converters and replaces them with a straight through design. This provides the absolute most flow possible which has shown gains on NA 350zs between 4-8HP making it one of the best "bang for the buck" mods. These pipes are an absolute must on FI cars which need all the flow possible. Constructed entirely of stainless steel and feature thick 3/8" flanges. They are completely TIG welded and also feature seamless mandrel bends. Tube diameter of 2.25" matches up perfectly with aftermarket exhausts like Borla, Injen, and Nismo. They retain the factory oxygen sensor mount and WILL NOT THROW A CHECK ENGINE LIGHT when run. These pipes will definitely make your exhaust note more aggressive. They have also tended to add a "raspy" exhaust note through the 3-4k range. This note has been loved by some, and hated by others, so it is not for the conservative. They use all factory mounting points and there is no modification to the vehicle. These will work with either aftermarket headers, factory headers, aftermarket exhaust, or factory exhaust. £179 20. 350z DE Motiv Concepts Test Pipes There's no better way to maximize the performance of your vehicle than with a set of high-performance test pipes. Get rid of the restrictive stock catalytic converters and let your VQ35DE breathe the way it was meant to be. Motiv Concepts' test pipes for the 03-06 Nissan 350Z does just that - featuring our signature beautiful brushed finish on 2.5-inch of U.S. made RathGibson tube. Complete bolt-on with all-new hardware, ready to go. Fits: 2003-2006 350Z with VQ35DE Motor 100-percent stainless steel construction U.S. made RathGibson 2.5-inch tube Signature beautiful brushed finish 3/8-inch thick stainless steel flanges Includes all new gaskets and hardware Complete bolt-on Made in U.S.A. with Lifetime Warranty £239 21. 350z HR Motiv Concepts Test Pipes Tired of those stock catalytic converters restricting the performance of your VQ35HR engine? Motiv Concepts' Test Pipes for the 07-09 350z are designed to maximize the horsepower from your engine, constructed from 2.5-inch U.S. made RathGibson tube done in our signature beautiful brushed finish. Our spaced-out O2 bungs help eliminate the potential of a 'check engine light', so you can bolt-them on with no worry and hit the track. Specs Fits: 2007-2008 350Z 100-percent stainless steel construction U.S. made RathGibson 2.5-inch tube Signature beautiful brushed finish 3/8-inch thick stainless steel flanges Includes all new gaskets and hardware Complete bolt-on Made in U.S.A. with Lifetime Warranty £249 22. 350z DE Motordyne Advanced Resonance Tuning - ART Test Pipes Through countless hours of research and development a new path has been explored in the never ending quest for performance. A method of directly altering exhaust harmonics for enhanced performance and sound, this is Motordyne's debut of the patent pending Advanced Resonance TuningTM. 15 to 20 Ftlbs more low end torque than conventional test pipes. ART pipes increase power and torque without the drastic increase in loudness normally associated with test pipes. These provide the quietest, smoothest, deepest sound while greatly reducing or eliminating rasp and drone. The difference in sound is not subtle. They're not conventional test pipes. They're ART pipes! 2 week lead time. Compatible with 2WD automatics. £499 23. 350z Motordyne XYZ Resonated Y-Pipe 4.5" Glass packed resonator with 3" outlet. With modular options of a straight pipe, a resonator or even a catalytic converter the XYZ-pipe allows functional advantages previously not seen in any other Y-pipe. The V-band clamp, different modules can be easily changed out in minutes. The XYZ is a fully optimized Y-pipe that offers the best of power, sound and emissions. With interchangeable modules, the Motordyne XYZ is a new evolution of exhaust versatility for the Nissan and Infiniti family. 2 week lead time. £399 24. 350z Motordyne XYZ 350Z Y-Pipe with Straight Pipe In its development phase, many different primary tube diameters, merge distances and merge angles were all dyno tested. It was found that performance is clearly affected by these variables. With multiple data points collected, a performance map was generated converging to the combination of best overall performance. £369 25. 350z Motordyne XYZ High Flow Cat Y-Pipe In its development phase, many different primary tube diameters, merge distances and merge angles were all dyno tested. It was found that performance is clearly affected by these variables. With multiple data points collected, a performance map was generated converging to the combination of best overall performance. £449 26. 350z DE PPE Stainless Steel Long Tube Race Headers The PPE 350Z long tube headers are designed for maximum power and midrange. Testing on a 2006 350Z showed an increase in top end power and midrange torque over shorty headers and testpipes. JetHot ceramic coatings come standard and add good looks along with thermal barrior properties that increase power and lower engine bay temps. They are also a great protection against corrosion. Features: -Equal length tubing -3/8" thick laser cut flanges -Mandrel bent 16 gauge tubing -Runners are welded with Silicabronze at the head flange -Porting at flanges -Flat sanded head flanges -Optional ceramic coatings -1yr warranty -For Off Road use only. The race headers replace the stock catalytic converters. Collector Option: Parallel Merge Collector w/ Spike: It smooths out the exhaust flow and simulates the inside of a parallel merge collector. It is supposed to flow 90% as well as a parallel merge collector. Without the spike there is a flat spot in the collector that creates turbulence and can slow down the exhaust gases. £1399 27. 350z HR PPE Stainless Steel Long Tube Race Headers The PPE 350Z long tube headers are designed for maximum power and midrange. Testing on a 2006 350Z showed an increase in top end power and midrange torque over shorty headers and testpipes. JetHot ceramic coatings come standard and add good looks along with thermal barrior properties that increase power and lower engine bay temps. They are also a great protection against corrosion. Features: -Equal length tubing -3/8" thick laser cut flanges -Mandrel bent 16 gauge tubing -Runners are welded with Silicabronze at the head flange -Porting at flanges -Flat sanded head flanges -Optional ceramic coatings -1yr warranty -For Off Road use only. The race headers replace the stock catalytic converters. Collector Option: Parallel Merge Collector w/ Spike: It smooths out the exhaust flow and simulates the inside of a parallel merge collector. It is supposed to flow 90% as well as a parallel merge collector. Without the spike there is a flat spot in the collector that creates turbulence and can slow down the exhaust gases. £1399 28. 350z DE Motiv Concepts High Flow Catalytic Converters There's no better way to maximize the performance of your vehicle than with a set of high-performance test pipes. Get rid of the restrictive stock catalytic converters and let your VQ35DE breathe the way it was meant to be. Motiv Concepts? test pipes for the 03-06 Nissan 350Z does just that - featuring our signature beautiful brushed finish on 2.5-inch of U.S. made RathGibson tube. Complete bolt-on with all-new hardware, ready to go. Specs Fits: 2003-2006 350Z with VQ35DE Motor 100-percent stainless steel construction U.S. made RathGibson 2.5-inch tube Signature beautiful brushed finish 3/8-inch thick stainless steel flanges O2 bung spaced out to eliminate potential sensor errors Includes all new gaskets and hardware Complete bolt-on Made in U.S.A. £419 29. 350z HR Motiv Concepts High Flow Catalytic Converters There's no better way to maximize the performance of your vehicle than with a set of high-performance test pipes. Get rid of the restrictive stock catalytic converters and let your VQ35DE breathe the way it was meant to be. Motiv Concepts? test pipes for the 03-06 Nissan 350Z does just that - featuring our signature beautiful brushed finish on 2.5-inch of U.S. made RathGibson tube. Complete bolt-on with all-new hardware, ready to go. Specs Fits: 2003-2006 350Z with VQ35DE Motor 100-percent stainless steel construction U.S. made RathGibson 2.5-inch tube Signature beautiful brushed finish 3/8-inch thick stainless steel flanges O2 bung spaced out to eliminate potential sensor errors Includes all new gaskets and hardware Complete bolt-on Made in U.S.A. £419 30. 350z DE Stillen Stainless Steel Test Pipes STILLEN Race Pipes replace the stock catalytic converters for unrestricted maximum exhaust flow. As race only parts, they delete the catalytic converters and are not street legal. The Race Pipes, combined with STILLEN's new performance headers, produce big increases in power and torque. Contributing to the performance gains along with the straight-through free-flowing design, is an expansion chamber that promotes more efficient exhaust scavenging. For example, the combination of STILLEN Headers and Race Pipes yield performance gains of 16 hp at @ 6200 RPM and 20 lb/ft @ 3800 RPM at the wheels for a 2003 Nissan 350Z as tested on the STILLEN Dyno. With STILLEN's 18 years of experience in designing and manufacturing Nissan performance parts, you should have complete confidence that every STILLEN product is of the highest quality and has under gone extensive research and development before production. £279 31. 350Z DE Stillen Metallic Hi-Flow Catalytic Converters STILLEN now has high flow replacement catalytic converters for the Nissan 350Z. These are for the enthusiast that wants the best flow possible, while remaining environmentally responsible. Though these converters are not CARB legal, they are a step above race or test pipes and will not result in a "raspy" tone. STILLEN Hi Flow Catalytic Converters reduce emissions and unpleasant exhaust smells. These pipes increase output by 9 HP and 8 ft/lbs of torque. £519 32. 350Z HR Stillen Metallic Hi-Flow Catalytic Converters STILLEN now has high flow replacement catalytic converters for the Nissan 350Z, 370Z, Infiniti G35, and G37 Coupe. These are for the enthusiast that wants the best flow possible, while remaining environmentally responsible. Though these converters are not CARB legal, they are a step above race or test pipes and will result in a less "raspy" tone. As high performance cats, some sound increase should be expected. STILLEN Hi Flow Catalytic Converters reduce emissions and unpleasant exhaust smells. Common gains for these HFCs are 9 HP on the 350Z and 16 HP on the 370Z. £499 33. 350z Stillen Stainless Steel Y-Pipe STILLEN Y-pipe is constructed of 2 1/2" pipe up to 3" on the collector and is made of stainless steel. This mandrel bent pipe allows for smooth flow of gasses without restriction, bringing the increase of performance to 7 horsepower with an additional 3lbs of torque to your 350Z or G35 Coupe. (Total of 10 HP are gain when used with the STILLEN Silver Series Y-Pipe Back Exhaust System) £249 34. 350z Tanabe Medalion Touring Y-Pipe The ultra efficient Y-Pipe eliminates huge restrictions found on the factory exhaust system's piping, and provides huge horsepower gains when used with Tanabe cat-back exhausts. £499 35. 350z DE Tomei EXPREME Straight Front 60mm Pipe TOMEI Expreme Downpipe It is commonly believed that performance efficiency can be improved by reducing the secondary exhaust pressure from the turbine. The torque will be affected when the pipes diameter is too wide. We here at TOMEI had invested over a year in researching all possible aspects and combinations for the best performance gain throughout the entire area. The end result was a decrease in exhaust resistance in all areas and best results is achieved with our Outlet ( dump pipe ) and front pipe as a combined set. £279 36. 350z DE Tomei EXPREME Headers Tomei EXPREME Exhaust Manifold Kit for Nissan VQ35DE 350Z and G35. The Tomei Expreme manifolds are made high quality certified T304 stainless steel and is tig welded for a more precise and perfect finish. What makes this kit unique is that this kit comes with everything seen in the picture for an all-in-one install kit. There is no need to buy extra gaskets, heat tape, or manifold accessories. This kit has it all to simplify installation! £829 37. 350z DE Tomei Expreme Hi-Flow Metal Catalytic Exhaust For achieving high output and high purification performance. In order to achieve both a high level of these two conflicting requirements, a number of prototypes to test many times over, was completed last EXPREME high performance meets quality standards. Small elements improve substantially VQ35DE output, but this varies by product. £1379 38. 350z Tomei Full Titanium Mid Y-Pipe This all new Mid Y Pipe from Tomei is a great addition to any race inspired 350Z. It creates extremely high exhaust flow and nets you extra horsepower in the process. While gaining horsepower is important the extra 12 pounds in weight savings on this full titanium piece is also a plus. £499 350Z HR Berk Technology Test Pipes Our highly anticipated 2007-up test pipes are now available! Features fully gusseted and plated support brackets, the strongest in the industry. Includes the same leak free soft crush graphite collector gaskets found in our 07- up HFC's and secondary O2 sensor bungs for wideband tuning or AF monitoring. Plugs included when not in use. Mechanical CEL fix included, but on the 07-up HR motors it is less effective than the 03-06 motors. Full 304 stainless steel construction, made the right way in the USA. £199 Edited April 20, 2015 by octet@TORQEN 3 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted February 9, 2015 Share Posted February 9, 2015 Some very interesting & cool items. Can't wait to see some pics. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 9, 2015 Author Share Posted February 9, 2015 Our guys are working on it, watermark and stuff, hundreds of photos to be done Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 23, 2015 Author Share Posted February 23, 2015 Photos added, more to come soon. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted February 23, 2015 Share Posted February 23, 2015 Later in the year I'm going for no:36. Quote Link to comment Share on other sites More sharing options...
martian68 Posted March 26, 2015 Share Posted March 26, 2015 (edited) . Edited March 26, 2015 by martian68 Quote Link to comment Share on other sites More sharing options...
Pritchard Posted August 13, 2015 Share Posted August 13, 2015 te PPE headers.... do they fit UK cars? i thought they didnt fit RHD? ....just asking because im looking Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 13, 2015 Author Share Posted August 13, 2015 They have designed RHD version so they fit! Quote Link to comment Share on other sites More sharing options...
