Adrian@TORQEN Posted February 9, 2015 Share Posted February 9, 2015 (edited) 1. 350z AAM Competition 2.5" MaxFlow True Dual Altered Atmosphere Motorsports is proud to announce our amazing AAM Spec 2.5" MaxFlow True Dual Exhaust System for the 350Z and G35. Maintaining a refined yet aggressive sound with sleek appearance this true dual design provides the perfect gain in power vs. sound and features dual 2.5 inch mandrel bent Aircraft Grade 16-Gauge T-304 stainless-steel. This is a true "cat-back" exhaust system as it replaces both the restrictive factory y-pipe, mid-pipe, and rear exhaust muffler section. Average horespower gain with this exhaust system is 12-16hp and torque! This is the perfect exhaust for both NA (naturally aspirated / non-supercharged or turbocharged) applications and forced induction (supercharged or turbocharged) applications where the AAM Spec 2.5" MaxFlow True Dual Exhaust System has been proven up to 500hp. Approx. Weight: 57 lbs. £1059 2. 350z AAM Competition 3" MaxFlow Single Exhaust The AAM Spec 3" MaxFlow Single Exhaust is specifically designed for those with extreme volume and velocity requirements. The AAM Spec 3" MaxFlow Single exhaust is the highest flowing single exhaust available for the 350Z and is a perfect match for Turbocharged street/strip 350Z?s or naturally aspirated/supercharged racing setups that require maximum flow. Specifically designed to not create the "boomy" highway resonance common on many other popular exhaust systems, the AAM Spec 3" MaxFlow Single exhaust is a y-pipe back exhaust system made of mandrel bent T-304 16-gauge stainless steel to ensure the highest reliability and quality. The mufflers are 3? N1 style high-flow turbo mufflers that produce a deep aggressive tone. The AAM Spec 3" MaxFlow Single exhaust gives our customers all the advantages (unrestricted flow and maximum horsepower) of a straight-through cat-back exhaust system while retaining an exhaust note as tame as possible. This combination of sound and maximum exhaust flow excels in both naturally aspirated applications and Supercharged 350Z's, while additionally working extremely well for our Turbocharged customers. The single, lightweight Stainless Steel Muffler guarantees excellent durability and corrosion resistance and comes fully polished with either a polished Stainless Steel or Titanium Tip. Dyno tested 10rwhp on a 2004 Nissan 350Z! AAM Spec 3" MaxFlow Single Exhaust: approx 33 lbs Weight savings: 30 lbs £699 3. 350z AAM Competition 3" MaxFlow Single Exhaust with Titanium Tip Specifically designed to not create the "boomy" highway resonance common on many other popular exhaust systems, the AAM Competition 3" Single exhaust is a y-pipe back exhaust system made of mandrel bent T-304 16-gauge stainless steel to ensure the highest reliability and quality. The mufflers are 3? N1 style high-flow turbo mufflers that produce a deep aggressive tone. The AAM Competition 3" Single exhuast gives our customers all the advantages (unrestricted flow and maximum horsepower) of a straight-through cat-back exhaust system while retaining an exhaust note as tame as possible. The 3" Rear Section is the perfect combination of sound and maximum exhaust flow excels in both naturally aspirated applications and Supercharged 350Z. The single, lightweight muffler guarantees excellent durability and corrosion resistance and comes with fully polished Stainless Steel Muffler and Titanium Tip. Dyno tested 10rwhp on a 2004 Nissan 350Z! £759 4. 350z AAM Competition 3" MaxFlow True Dual Exhaust The flagship of the AAM 3" exhaust line, the AAM Spec 3" MaxFlow True Dual Exhaust System is the highest flowing exhaust available for the 350Z & G35. Designed to support the most demanding volume and velocity flow requirements, the AAM Spec 3" MaxFlow True Dual exhaust system is a perfect match for any Turbocharged 350Z, including 800rwhp+ competition setups. The AAM Spec 3" MaxFlow True Dual exhaust system comes with a specially designed 3? inner diameter flange on each side that bolts-up to either the factory cat pipes or most aftermarket 2.5" test pipes. Twin mandrel bent 3? polished stainless steel T-304 16 Gauge exhaust tubes run along each side of the 350Z's undercarriage. Two high-flow stainless steel resonators ensure straight through flow and a deep exhaust note. By significantly decreasing thermal load, the AAM Spec 3" Max Flow True Dual exhaust system provides the maximum reliability for your VQ35 engine and its internal components. Preliminary testing has shown gains over 40rwhp on high horsepower turbocharged Z's vs. the factory exhaust. The AAM 3" Max Flow True Dual is the ultimate 350Z exhaust and an engineering work of art. Available with Titanium Tips. £1189 5. 350z AAM Competition 3" MaxFlow True Dual Exhaust with Titanium tips The flagship of the AAM 3" exhaust line, the AAM Spec 3" MaxFlow True Dual Exhaust System is the highest flowing exhaust available for the 350Z & G35. Designed to support the most demanding volume and velocity flow requirements, the AAM Spec 3" MaxFlow True Dual exhaust system is a perfect match for any Turbocharged 350Z, including 800rwhp+ competition setups. The AAM Spec 3" MaxFlow True Dual exhaust system comes with a specially designed 3? inner diameter flange on each side that bolts-up to either the factory cat pipes or most aftermarket 2.5" test pipes. Twin mandrel bent 3? polished stainless steel T-304 16 Gauge exhaust tubes run along each side of the 350Z's undercarriage. Two high-flow stainless steel resonators ensure straight through flow and a deep exhaust note. By significantly decreasing thermal load, the AAM Spec 3" Max Flow True Dual exhaust system provides the maximum reliability for your VQ35 engine and its internal components. Preliminary testing has shown gains over 40rwhp on high horsepower turbocharged Z's vs. the factory exhaust. The AAM 3" Max Flow True Dual is the ultimate 350Z exhaust and an engineering work of art. Available with Titanium Tips. £1399 6. 350z Agency Power SS Catback Exhaust System The need for power, quality, and style has once again been executed by Agency Power with their brand new catback exhaust system for the Nissan 350Z. This new stainless steel exhaust system features a single titanium muffler setup with a titanium 4.5 inch tip etched with the Agency Power logo. The system utilizes T304 stainless steel 3 inch piping TIG welded with 1/2 inch thick flanges. The Agency Power catback exhaust includes strong durable hangers, gaskets, and hardware for a perfect fitment. The complete exhaust will fit to the factory cat on your 2003 and up Nissan 350Z. The exhaust will give you a large gain in horsepower and torque (see dyno sheets). The race sound of the exhaust will not drone inside the car but give you that quality tone you desire (listen to sound clip). £749 7. Apexi N1 Titanium single Exhaust System The N1 Muffler series has evolved once again! The N1 ExTi (Expert Titanium) offers all the performance and quality of our race proven N1 Exhaust systems plus the incorporation of an ultra light weight titanium muffler section. For years, the N1 Titan has only been available to our customers in Japan; at A?PEX USA we are very pleased to be able to offer this muffler to the US tuning market under the N1 ExTi name. The N1 ExTi utilizes full stainless steel piping mated to an immaculately constructed Titanium N1 Muffler. The muffler section features a full titanium canister which discharges through an adjustable length 115mm super heated (burnt) titanium tip. The 5 step adjustment range of the finisher tip is designed to allow users with aero kits the ability to extend or retract the tip to meet the dimensions of the rear bumper. The N1 ExTi stands as a true lightweight version of the N1 exhaust, successfully blending form with function. Single Exhaust Pipe = 70mm.-80mm. Tip = 115mm £979 8. 350z ARK Performance GRiP 2.5" Pipe True Dual / 4.0" Slip Tip Exhaust SLIP BURNT Nissan 350Z 2003-2008, GRiP Stainless Steel Cat-Back Exhaust System with Burnt Tip by ARK Performance®. 2.5" Pipe True Dual and 4.0" Slip Tip. The ARK "GRiP" exhaust system provides the serious enthusiast a combination of sound, style, and quality craftmanship. As a leader and innovator in aftermarket exhaust systems we are highly recognized for ARK exclusive designs, proven HP/Torque performance gains, and their significant ARK exhaust note sound that is resonant, pure, rich, and deep. £1129 9. 350z B&B Performance Exhaust System Billy Boat Performance Exhaust has once again proven they are the leader in the aftermarket exhaust industry by introducing a system for the 350Z. Built for performance, sound, and style the B&B system shows an increase in both horsepower and torque across the RPM range with peaks of 8.2 wheel HP and 8.5 ft.lbs of torque. Mandrel bent and manufactured from 100% T-304 stainless steel, the B&B system for the 350Z installs quickly and easily requiring absolutely no cutting, welding or modification for installation. The 4.5" Elliptical tips and fully polished muffler enhance and blend with the styling of the vehicle while providing a distinguished look. Twin 4.5" Elliptical Tips £829 10. 350z Blitz Nur Spec Touring Exhaust System Blitz Nur Spec Touring Exhaust System is rated as the highest quality exhaust system in terms of performance and looks. Made of high quality stainless steel and utilizing a slanted mounting design, unnecessary bends are eliminated to bring you the most possible smooth exhaust flow. Along with mandrel bent piping, this exhaust system gives you all the performance you'll expect out of Blitz's Nur Spec Touring line of exhaust. Blitz Nur Spec Touring line averages a 5-20 horsepower gain. This exhaust system is designed for maximum performance, apperance, and aggressive tone. This exhaust system comes with all hardware and gaskets needed for a bolt-on installation using all the factory hanger points. £1299 11. 350Z Borla True Dual Exhaust SS System The Borla True Dual Exhaust SS System is one of the best Exhaust systems on the market for the 350Z. The System uses a true Dual Design, which eliminates the Y-pipe. This results in better flow and more HP. The HP gains have resulted as 16-20 HP. The System weighs about 12lbs less than the Stock System on the car.These systems will fit any 03-08 350Z £1199 12. 350z Borla True Dual Exhaust Header Combo Our Exhaust Header Combo Includes Borlas Amazing True Dual Exhaust System, and SS Headers. The Borla True Dual Exhaust SS System is one of the best Exhaust systems on the market for the 350Z. The System uses a true Dual Design, which eliminates the Y-pipe. This results in better flow and more HP. The HP gains have resulted as 16-20 HP. The System weighs about 12lbs less than the Stock System on the car. With the combination of Headers, you will experience more exhaust flow through the complete system. £1849 13. 350z DC Sports Single Canister Cat Back Exhaust DC Sports Single Canister exhaust systems are dyno tuned and tested to outperform all comparable systems on the market. Our Single Canister systems feature a polished round barrel-style canister and a straight-cut, four-inch tip with rolled DC Sports logo. Years: 03-08 Single Canister System Stainless Steel Cat Back Exhaust Dual Exit With X Pipe £619 14. 350Z Fujitsubo Legalis-R Exhaust Fujitsubo was originally established in 1937 as a motorcycle manufacturer. Fujitsubo Motors produced the first Japanese made motorbike called the Eagle. In 1965, Fujitsubo started manufacturing automobile parts and now holds more than 12 patents. Fujitsubo continue to be leading edge in the exhaust components and is one of the most respected performance exhaust manufacturer in Japan. Fujitsubo exhaust systems are well-known for their exceptional quality and engineered to increase power while maintaining a deep quiet tone. Fujitsubo product testing and development has been conducted in various forms of motorsports including WRC, Super Taikyu, D1GP, Gymkhana, Dirt Trial, and Formula 4 plus on Fujitsubo's on site 1/4 mile test strip. All of Fujitsubo's testing has enabled them to become ISO 9001 certified, JASMA certified, and a TUV license holder. It's not surprising to see a Fujitsubo exhaust system on many of Japan's top race cars in the JGTC (Japan Grand Touring Championship). The Legalis R exhaust is Fujitsubo's most popular exhaust system. Designed for street use, it improves both low-end and mid-range power. All Fujitsubo Legalis R exhaust systems are constructed of stainless steel and are available in two different tip styles. Round with slanted tip or oval, depending on the car application. All Fujitsubo exhaust systems are bolt-on and come with all necessary bolts and hardware for easy installation. Application: Fujitsubo Legalis-R Dual Axleback Exhaust Nissan 350Z 2003-2006 Z33 Pipe Diameter (mm) 76.3-60.5 Tip Diameter (mm) 117 Noise Level (dB) 83 Muffler Outlet Dual Exhaust Tips 2 For Chassis Z33 Notes: This is an axleback exhaust system. Use OE Y pipe £1649 15. 350z Greddy Racing Sport RS Exhaust System GReddy Racing Sport (RS) Cat-back Exhaust combine a high flow straight-through design, polished stainless-steel construction and aggressive sound. A combination worthy for the street. The Greddy Racing Sport (RS) Exhaust systems for the Nissan 350z are comprised of full polished stainless steel muffler and an interchangeable tip, unpolished stainless steel piping. £1149 16. 350Z Greddy SP Elite Rear Section Exhaust System The SP Elite, is GReddy's latest version of this full stainless-steel legacy. Similar in style to the Spectrum Elite line, the SP Elite uses a larger high flow piping, straight-through oval muffler(s) and resonated angled tip(s) for a sporty, yet refine exhaust note. However the SP Elite, has a more standard finished polished tip, stamp strengthen end caps and un-embossed muffler body, resulting in more affordable, more subtle, Sport Performance Exhaust. £579 17. 350z GReddy Revolution RS Stainless Steel Catback Exhaust System The Revolution RS for the Nissan 350Z is ideal for turbocharged VQ35s but also makes great power for normally aspirated applications. The full dual 3†Y-back, cat-back exhaust features a dual resonator cross-over pipe for sound control and equalizing exhaust pressures. Aggressive dual Revolution RS muffler canisters are angled match the Z looks while making room for the included EVAP canister relocation kit. Extra long 150mm length tips finish off the system under the factory bumper cut-outs. Like all GReddy Revolution RS systems the fully hand-welded 304 Stainless-Steel exhaust carries a Limited Lifetime Warranty. Piping: 76mm (3.0") Tip(s): 115mm (4.5") 2x Gasket(s): 3.0" oval (qty: 4 included) replacement Resonator: 2x H-pipe Weight: TBA lbs (Stock weight TBA lbs) Sound level: 101 dB(a) HP: +10 hp TRQ: +7 ft-lbs £1249 18. 350z HKS Catback Exhaust System, Full Dual Muffler The HKS Full Dual exhaust is only available for the 350Z and features full exhaust piping for each engine bank, right to the tail. This provides improved exhaust flow and reduces interference. Stainless Steel SUS304 construction and Titanium tail 1.2mm pipe wall thickness 3 Piece design, 2x 60mm Piping & 110mm Tail Left & Right Noise volume approaching 87db compared to standard 80db Balance pipe to ensure no pipe stress at low RPM £2949 19. 350z HKS Catback Exhaust System - Hi-Power Stainless Steel Titanium Tip Full Dual Polished SUS304 Stainless Steel Piping w/Dual Titanium Tips (adjustable length), Includes H Pipe - Tip: HP-Ti - Tip Diameter: 120mm - Piping Diameter: 60mm Inspired and designed from endurance and GT racing in Japan, HKS developed its Hi-Power Exhaust system for both turbocharged and naturally aspirated applications. HKS has incorporated this new race inspired offset muffler and piping design into many street applications, which offers a greater flow and higher-PRM power gains due to the less restrictive design. This is achieved by eliminating unnecessary bends for the straightest exhaust path. £1629 20. 350z Injen SES Titanium Tip Exhaust System Nissan The Injen SES Titanium Tip Exhaust System is a True Dual Tip Cat Back System. With a reputation like Injen, and a sports car dominance like the Z, these two combinations make an awesome team. The Injen Exhaust System is a full stainless steel system, so you don't have to worry about ever replacing it. With a 16HP Gain, the highest gain out of any exhaust on the market, you can't go wrong. Injen Technology introduces its unique flared tip design with removable stainless steel silencers. Dyno Results: 15.9 RWHP Increase £1149 21. 350Z Invidia Gemini Rolled Titanium Tip Cat-Back Exhaust Invidia produces high performance parts for today?s hottest tuner cars. Invidia knows that automotive enthusiasts are constantly looking for ways to extract more power from their engines and improve the driving experience. Using only the highest quality materials Invidia manufactures components that improve performance while remaining stylish. Invidia manufactures their exhaust systems specifically for each application to guarantee precise fitment and power gains. Invidia has applied their knowledge of automotive performance to a myriad of makes and models constantly refining and improving their product and design process. Invidia offers several exhaust system product lines to meet the expectations of nearly any automotive enthusiast. £799 22. 350z Invidia Gemini Rolled Stainless Steel Tip Cat-Back Exhaust System Invidia catback exhaust systems are designed specifically to improve performance, they achieve this by reducing bends in the exhaust system, using larger diameter piping. The reduced restriction also gives your vehicle a more aggressive tone for the sport enthusiast to enjoy. This improves throttle response, torque, horsepower and the overall driving experience. Catback exhausts are one of the most popular mods amongst casual and hardcore automotive enthusiasts alike. Their affordability, increase in performance, improved sound, and ease of installation make catback exhaust systems a perfect modification for nearly any vehicle. £799 23. 350z Invidia Gemini Single Layer Titanium Tip Cat-Back Exhaust System Invidia catback exhaust systems are designed specifically to improve performance, they achieve this by reducing bends in the exhaust system, using larger diameter piping. The reduced restriction also gives your vehicle a more aggressive tone for the sport enthusiast to enjoy. This improves throttle response, torque, horsepower and the overall driving experience. Catback exhausts are one of the most popular mods amongst casual and hardcore automotive enthusiasts alike. Their affordability, increase in performance, improved sound, and ease of installation make catback exhaust systems a perfect modification for nearly any vehicle. £799 24. Invidia 60mm Regular N1 Y-Pipe Back Exhaust System For a good balance of price and performance, Invidia offers the motorsport enthusiasts a strong line-up of Invidia N1 Exhausts. Each Invidia Exhaust is constructed with high quality SUS304 Stainless Steel, CNC-machined flanges, and manufactured with a polished finish. Each system features mandrel-bent stainless steel piping for maximum exhaust flow and reduced back pressure. These exhausts are engineered to produce strong mid to top-end power gains, as well as an increase in horsepower and torque. £569 25. 350z Magnaflow Stainless Cat-Back Exhaust Magnaflow 15765 Stainless Cat-Back Exhaust System 03-08 Nissan 350Z Features: Material: 100% Stainless Steel Tubing O.D. Size: 2.5in. System Type: Cat-Back TIP O.D. Size: 4in. TIP Quantity: 2 Single/Dual: Single Exit Position: DUAL SPLIT REAR EXIT Lifetime Warranty, Dyno Tested And Proven To Make Power, Performance Gains In Horsepower And Torque, Great Sound -Has A Smooth; Deep Tone, Easy To Install, Mandrel-Bent. All Welded. Built To Last. £699 26. 350z Magnaflow Stainless Cat-Back Exhausts System Magnaflow 16784 Stainless Cat-Back Exhausts System 03-08 Nissan 350Z Features: Material: 100% Stainless Steel Tubing O.D. Size: 3in. System Type: Cat-Back TIP O.D. Size: 4in. TIP Quantity: 2 Single/Dual: Dual Exit Position: DUAL SPLIT REAR EXIT Lifetime Warranty, Dyno Tested And Proven To Make Power, Performance Gains In Horsepower And Torque, Great Sound -Has A Smooth; Deep Tone, Easy To Install, Mandrel-Bent. All Welded. Built To Last. £949 27. 350z Megan Racing OE-RS Megan Racing OE-RS series cat backs are based on factory style, with bigger piping, OEM style polished mufflers and quiet sound. The cat back system is made stainless steel. All pipiing are mandrel bent with a high polished finish. Exhaust system comes with all the necessary hardware needed for a direct bolt on installation. Improves HP with minimal noise. £499 28. 350z Motordyne Shockwave TDX2 Catback Exhaust System The Motordyne Shockwave V2 exhaust for your 03-08 Nissan 350Z is a true dual X-pipe exhaust system engineered to produce the highest levels of torque and horsepower from the VQ35 engine. Motordyne exhaust systems are the product of extensive R&D and outstanding craftsmanship. The Shockwave V2 strategically employs dual 2.5" primary tubes and dual 3.0" exhaust tubing to provide the best overall power gains. The Shockwave V2 improves upon its successor with the addition of resonator chambers to reduce drone and improve the tone of the exhaust. Motordyne produces high-quality intake and exhaust components for Nissan vehicles. Motordyne has always been quick to test their products against competitors and they routinely come out on top thanks to a steadfast commitment to thorough R&D and outstanding craftsmanship. Choosing Motordyne components for your vehicle is a good way to ensure that you receive only the highest quality and most thoroughly proven performance products on the market. £1629 29. 350Z Stillen Exhaust System - True Dual Cat Back Stainless Steel STILLEN'S hot new exhaust for the 350Z is the result of months of development and testing. Made of 100% stainless steel, the system features a lifetime warrantee. It makes the most power of any 350Z system on the market and fits like a glove. Tested to add 13 HP at 5600 rpm and 14 Ft/Lbs at 4600 rpm. This is the first and best full cat back system available for the 350Z. The power and mellow tone have to be experienced to be fully appreciated. Ships in two boxes. £1249 30. 350z Tanabe Medalion Touring Catback Exhaust The elegant, well defined appearance of Tanabe MEDALION TOURING exhaust for the 2003-2007 Infiniti G35 Coupe is mature, and matches the artistry of a tastefully built, highly tuned machine. Using the all new 'continuous strand' ADVANTEX packing material technology, MEDALION TOURING achieves extremely high levels of exhaust system efficiency, while maintaining a street driveable, extremely low frequency and deep tone that is well under 93db for discreet sports driving. Years: 03-07 Pipe Diam.: 70mm Tip Diam.: 115mm Single Canister Dual Tip w/Heat Shield £829 31. 350z Tanabe Medallion Concept G Y-Pipe Back Exhaust CONCEPT G is an all new motorsports-developed exhaust system that features high power benefits, while maintaining responsible sound levels. Using the all new 'continuous strand' ADVANTEX packing material technology, CONCEPT G acheives extremely high levels of exhaust system efficiency, while maintaining a street driveable, extremely clean sound output that is under 93db. The full SUS304 stainless CONCEPT G is designed for optimal pipe routing as well as ground clearance. It's sporty appearance and angle-cut tip is ideal for the sports car & sport compact driver. £829 32. Tomei Expreme Ti Full Titanium Single Exit Exhaust System Unlike most exhaust systems that focus only on maximum peak power, Tomei's main priority was for overall engine performance gains. Every tube's length and size were carefully picked to suit each engine's characteristics and chassis to maximize torque, response and exhaust flow efficiency from start to finish. The use of Titanium materials with the single piping layout reduce the overall weight from approx. 45 pounds to an ultra-low 10 pounds. High quality production, for true competition use without compromise. Only the best Titanium grade materials are used. From the special racing layout design, made as straight as possible, to the high flow silencer. We have poured our knowledge into it all. When you see our EXPREME Ti system, you can then understand that ours is unrivaled. Exhaust flow design was the main focus in the pipe design, the best pipe thickness for weight and strength with pipe diameter to suit torque and all power gains throughout the entire power band. Key Features: Material: Titanium Main Pipe Diam: 80mm Main Pipe Thickness: 1mm Silencer Diameter: 152mm Tip Exit Diameter: 115mm Weight: 5.9kg £949 33. 350z Top Speed Pro-1 True Dual HKS Replica Cat-Back Exhaust System Real Titanium Tip The Top Speed 350Z Exhaust is mandrel-bent and robotic TIG welded using properly sized tubing for maximum flow and is finished off with a low restriction racing muffler. Improve overall performance, Increase Horsepower and Torque. 2.5" Piping, 4.5" Titanium Tip. All Hardware Included for easy installation. £549 More options and photos to follow shortly. Edited September 25, 2015 by octet@TORQEN 1 Quote Link to comment Share on other sites More sharing options...
Neilp Posted February 9, 2015 Share Posted February 9, 2015 So much choice. not enough money Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 9, 2015 Author Share Posted February 9, 2015 (edited) Get a second job! More options to come in a few minutes Edited February 9, 2015 by TORQEN 1 Quote Link to comment Share on other sites More sharing options...
Kev Posted February 20, 2015 Share Posted February 20, 2015 Tempted by a tanabe for the summer. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 20, 2015 Author Share Posted February 20, 2015 PM sent Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 23, 2015 Author Share Posted February 23, 2015 Some photos added, more to come soon. Adrian Quote Link to comment Share on other sites More sharing options...
Jack wellZ Posted March 19, 2015 Share Posted March 19, 2015 Damn, the problem of deciding between ark or motordyne!! Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted March 19, 2015 Author Share Posted March 19, 2015 Sold 2 Motordyne this week, one arriving today. We have stock, ready to ship from USA tomorrow. PM me if you'd like to order. Adrian Quote Link to comment Share on other sites More sharing options...
kkong6 Posted September 28, 2015 Share Posted September 28, 2015 Pm'd you mate, after a new system for my zed asap Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted September 28, 2015 Author Share Posted September 28, 2015 Reply on the way! Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted September 28, 2015 Author Share Posted September 28, 2015 Just to mention, this page hasn't been updated for a while, you may find some of the prices are not accurate, best to PM me for prices. Website should be up soon, all prices are up to date Adrian Quote Link to comment Share on other sites More sharing options...
valy Posted September 28, 2015 Share Posted September 28, 2015 indeed Adrian,Tarmac sells the Ark grip for £1050... Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted September 28, 2015 Author Share Posted September 28, 2015 Go for it Valy Quote Link to comment Share on other sites More sharing options...
valy Posted September 28, 2015 Share Posted September 28, 2015 in the spring is the first thing I'll get....will see what prices will be like then Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted September 28, 2015 Author Share Posted September 28, 2015 Don't forget to pair it with ARK R-Spec pipes for awesome sound. PM me when you're ready and we'll see what we can do Adrian 1 Quote Link to comment Share on other sites More sharing options...
