JakeeyB Posted February 6, 2015 Share Posted February 6, 2015 Removed all the screws as it says in the guide. Got to the part where it said to 'gently pull towards you' but it won't move.. am i missing something here? Quote Link to comment Share on other sites More sharing options...
KUGT4 Posted February 7, 2015 Share Posted February 7, 2015 Yeah, i've abandoned my head unit swapping 'project' for now until i can figure this one out too Apparently you pull it towards yourself - but can't get enough grip at the top to move it... Quote Link to comment Share on other sites More sharing options...
Zedd Posted February 7, 2015 Share Posted February 7, 2015 If you've got all the screws out it should just pull towards you, I did use a little bit of force, but be careful when pulling as the pods connector is right at the top.How many screws have you taken out? As one of the times I forgot to take 2 of them out and spent about 10 mins wondering why it wouldn't pop out lol Quote Link to comment Share on other sites More sharing options...
GMballistic Posted February 7, 2015 Share Posted February 7, 2015 If you have some interior trim removal tools it might make it a bit easier so you can lift the back up enough to get some fingers under for a good grip. Here's a good guide in case you're following a different one: http://liljerk.morpheus.net/350Z/dash_removal/ Maybe double check you've undone all the screws as Zedd mentioned. Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted February 8, 2015 Share Posted February 8, 2015 This is the best guide for removing the centre consol well done G Quote Link to comment Share on other sites More sharing options...
Mudman Posted February 8, 2015 Share Posted February 8, 2015 Don't forget to unplug the pod connectors ! Both of them Quote Link to comment Share on other sites More sharing options...
Dicky Posted February 8, 2015 Share Posted February 8, 2015 I did the Bose hack a few weeks ago and also had a job pulling the console forward and out following removal of the indicted screws. Referring to the pictures in the GMballistic link above.....and assuming you were able to pull the top of the console away (the bit where the 3 gauge pod is ..see picture 12) Mine wouldn't pull out because the two brackets on each side of the Bose unit that hold it in place (ie the brackets with 4 screws each side holding it in) were catching right down at the bottom where they are secured at the same point as the white air con conontrol box ...see picture 17. The brackets are curved at the bottom and you can see the securing holes in them in picture 17 To get the console out I had to also remove the two screws securing each of these brackets (you can see the two black screws at the LHS of the picture at the bottom) Once I removed them the console fell out and I was able to see what had caused the removal problem. However as I said earlier if you can wiggle the bottom curved bits of these brackets past any obstructions then the console will come out without the need to remove these screws I've just mentioned Hope this is clear and can help Quote Link to comment Share on other sites More sharing options...
JakeeyB Posted February 10, 2015 Author Share Posted February 10, 2015 Cheers guys! Turns out one of the clips at the top was caught on the foam wrapped around the pod wires which made it difficult to pull away! But nothing is damaged thank god Quote Link to comment Share on other sites More sharing options...
GMballistic Posted February 10, 2015 Share Posted February 10, 2015 Good result then in the end. Happy you got it sorted. Quote Link to comment Share on other sites More sharing options...
