Adrian@TORQEN Posted February 6, 2015 Share Posted February 6, 2015 Circuit Sports Wheel Spacer Set, 15mm 370Z Circuit Sports wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). Circuit Sports wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. 5x114.3, 12x1.25mm Built-In Studs. Sold as a pair, will fit either front or rear wheels. £109 Circuit Sports Wheel Spacer Set, 20mm 370Z Circuit Sports wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). Circuit Sports wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. 5x114.3, 12x1.25mm Built-In Studs. Sold as a pair, will fit either front or rear wheels. £109 Circuit Sports Wheel Spacer Set, 30mm 370Z Circuit Sports wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). Circuit Sports wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. 5x114.3, 12x1.25mm Built-In Studs. Sold as a pair, will fit either front or rear wheels. £119 H&R Trak+ 5mm Wheel Spacer Kit 5x114.3 DRS DRS SERIES 10 - 40 mm track widening This spacer is fitted between the wheel and hub, exchanging the existing wheel studs for longer ones. The wheels are then fitted to the hub/spacer with the existing wheel nuts. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. £59 H&R Trak+ 10mm Wheel Spacer Kit 5x114.3 DRS 10 - 40 mm track widening This spacer is fitted between the wheel and hub, exchanging the existing wheel studs for longer ones. The wheels are then fitted to the hub/spacer with the existing wheel nuts. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. £79 H&R Trak+ 15mm Wheel Spacer Kit 5x114.3 DRS 10 - 40 mm track widening This spacer is fitted between the wheel and hub, exchanging the existing wheel studs for longer ones. The wheels are then fitted to the hub/spacer with the existing wheel nuts. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. £109 H&R Trak+ 20mm Wheel Spacer Kit 5x114.3 DRS 10 - 40 mm track widening This spacer is fitted between the wheel and hub, exchanging the existing wheel studs for longer ones. The wheels are then fitted to the hub/spacer with the existing wheel nuts. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. £109 H&R Trak+ 15mm Wheel Spacer Kit 5x114.3 DRM DRM Series DRM Series spacers bolt to the hub with existing wheel studs and special nuts (included). Wheel is bolted to new DRM wheel studs. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. Hub centric for the highest level of accuracy. 10mm and 15mm Bolt-On Wheel Spacers will not fit with front stock wheels for the 370Z. Only 20mm+ Bolt-On spacers will work. Only Ichiba Type 1 and H&R Type DRS Wheel Spacers will work for stock 370Z front wheels if you are looking for 10mm or 15mm wheel spacers. £129 H&R Trak+ 20mm Wheel Spacer Kit 5x114.3 DRM DRM Series DRM Series spacers bolt to the hub with existing wheel studs and special nuts (included). Wheel is bolted to new DRM wheel studs. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. Hub centric for the highest level of accuracy. £129 H&R Trak+ 25mm Wheel Spacer Kit 5x114.3 DRM DRM Series DRM Series spacers bolt to the hub with existing wheel studs and special nuts (included). Wheel is bolted to new DRM wheel studs. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. Hub centric for the highest level of accuracy. £129 H&R Trak+ 30mm Wheel Spacer Kit 5x114.3 DRM DRM Series DRM Series spacers bolt to the hub with existing wheel studs and special nuts (included). Wheel is bolted to new DRM wheel studs. TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. Hub centric for the highest level of accuracy. £149 CZP Wheel Spacer Set, 25mm 370Z CZP wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). CZP wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. 5x114.3, 12x1.25mm Built-In Studs. Sold as a pair, will fit either front or rear wheels. £119 Eibach Pro Wheel Spacers 5mm 5x114.3 To give your car the final visual and performance touch, our engineers have created a complete line of Eibach Pro-Spacers. These are designed to give your vehicle a wider, more stable stance, quickly and easily. They are also a perfect match for the famous Eibach Pro-Kit or Sportline Lowering Spring Sets. With the right Eibach Pro-Spacers installed, your car takes on a more aggressive look, with the wheels and tires?filling the wheel arches exactly the way they should. Fine-tuning your track width doesn't just enhance your car's looks it also gives you improved handling performance and optimized roll characteristics. Pro-Spacers are available in a wide range of sizes, from 5mm all the way to 45mm, depending on the application, letting you position your tires exactly where they will look and perform their best. In many cases, installing the right Pro-Spacers can improve the look and function of your existing wheels and tires so much, you might not need to buy new custom wheels and tires at all. Features: • Widen Your Stance For Better Handling • Made from High-Strength Aircraft-Aluminum Alloy • Precision Engineered Hub-Centric and Model Specific for Perfect Fit and Wheel Balance • Strength-Tested for All Applications • Extreme corrosion Protection Through DIN 50021 Approved Coating Process • TUV, QS9000 and ISO9001 Quality Approved • Reduced Weight Compared to Steel Wheel Spacers £79 Eibach Pro Wheel Spacers 10mm 5x114.3 To give your car the final visual and performance touch, our engineers have created a complete line of Eibach Pro-Spacers. These are designed to give your vehicle a wider, more stable stance, quickly and easily. They are also a perfect match for the famous Eibach Pro-Kit or Sportline Lowering Spring Sets. With the right Eibach Pro-Spacers installed, your car takes on a more aggressive look, with the wheels and tires?filling the wheel arches exactly the way they should. Fine-tuning your track width doesn't just enhance your car's looks it also gives you improved handling performance and optimized roll characteristics. Pro-Spacers are available in a wide range of sizes, from 5mm all the way to 45mm, depending on the application, letting you position your tires exactly where they will look and perform their best. In many cases, installing the right Pro-Spacers can improve the look and function of your existing wheels and tires so much, you might not need to buy new custom wheels and tires at all. Features: • Widen Your Stance For Better Handling • Made from High-Strength Aircraft-Aluminum Alloy • Precision Engineered Hub-Centric and Model Specific for Perfect Fit and Wheel Balance • Strength-Tested for All Applications • Extreme corrosion Protection Through DIN 50021 Approved Coating Process • TUV, QS9000 and ISO9001 Quality Approved • Reduced Weight Compared to Steel Wheel Spacers £109 Eibach Pro Wheel Spacers 15mm 5x114.3 To give your car the final visual and performance touch, our engineers have created a complete line of Eibach Pro-Spacers. These are designed to give your vehicle a wider, more stable stance, quickly and easily. They are also a perfect match for the famous Eibach Pro-Kit or Sportline Lowering Spring Sets. With the right Eibach Pro-Spacers installed, your car takes on a more aggressive look, with the wheels and tires?filling the wheel arches exactly the way they should. Fine-tuning your track width doesn't just enhance your car's looks it also gives you improved handling performance and optimized roll characteristics. Pro-Spacers are available in a wide range of sizes, from 5mm all the way to 45mm, depending on the application, letting you position your tires exactly where they will look and perform their best. In many cases, installing the right Pro-Spacers can improve the look and function of your existing wheels and tires so much, you might not need to buy new custom wheels and tires at all. Features: • Widen Your Stance For Better Handling • Made from High-Strength Aircraft-Aluminum Alloy • Precision Engineered Hub-Centric and Model Specific for Perfect Fit and Wheel Balance • Strength-Tested for All Applications • Extreme corrosion Protection Through DIN 50021 Approved Coating Process • TUV, QS9000 and ISO9001 Quality Approved • Reduced Weight Compared to Steel Wheel Spacers £149 Eibach Pro Wheel Spacers 20mm 5x114.3 To give your car the final visual and performance touch, our engineers have created a complete line of Eibach Pro-Spacers. These are designed to give your vehicle a wider, more stable stance, quickly and easily. They are also a perfect match for the famous Eibach Pro-Kit or Sportline Lowering Spring Sets. With the right Eibach Pro-Spacers installed, your car takes on a more aggressive look, with the wheels and tires?filling the wheel arches exactly the way they should. Fine-tuning your track width doesn't just enhance your car's looks it also gives you improved handling performance and optimized roll characteristics. Pro-Spacers are available in a wide range of sizes, from 5mm all the way to 45mm, depending on the application, letting you position your tires exactly where they will look and perform their best. In many cases, installing the right Pro-Spacers can improve the look and function of your existing wheels and tires so much, you might not need to buy new custom wheels and tires at all. Features: • Widen Your Stance For Better Handling • Made from High-Strength Aircraft-Aluminum Alloy • Precision Engineered Hub-Centric and Model Specific for Perfect Fit and Wheel Balance • Strength-Tested for All Applications • Extreme corrosion Protection Through DIN 50021 Approved Coating Process • TUV, QS9000 and ISO9001 Quality Approved • Reduced Weight Compared to Steel Wheel Spacers £149 Eibach Pro Wheel Spacers 25mm 5x114.3 To give your car the final visual and performance touch, our engineers have created a complete line of Eibach Pro-Spacers. These are designed to give your vehicle a wider, more stable stance, quickly and easily. They are also a perfect match for the famous Eibach Pro-Kit or Sportline Lowering Spring Sets. With the right Eibach Pro-Spacers installed, your car takes on a more aggressive look, with the wheels and tires?filling the wheel arches exactly the way they should. Fine-tuning your track width doesn't just enhance your car's looks it also gives you improved handling performance and optimized roll characteristics. Pro-Spacers are available in a wide range of sizes, from 5mm all the way to 45mm, depending on the application, letting you position your tires exactly where they will look and perform their best. In many cases, installing the right Pro-Spacers can improve the look and function of your existing wheels and tires so much, you might not need to buy new custom wheels and tires at all. Features: • Widen Your Stance For Better Handling • Made from High-Strength Aircraft-Aluminum Alloy • Precision Engineered Hub-Centric and Model Specific for Perfect Fit and Wheel Balance • Strength-Tested for All Applications • Extreme corrosion Protection Through DIN 50021 Approved Coating Process • TUV, QS9000 and ISO9001 Quality Approved • Reduced Weight Compared to Steel Wheel Spacers £149 Photos to follow. Quote Link to comment Share on other sites More sharing options...
