***TORQEN*** LOWEST PRICE 350Z Akebono Nissan Front & Rear 14" Big Brake Kit Upgrade
Adrian@TORQEN
Akebono Nissan 350Z Front & Rear 14" Big Brake Kit Upgrade
Featuring 14" diameter, 32mm vented rotors in front and 13.8" diameter, 20mm vented rotors in the rear, these brakes are absolutely huge. The front calipers use quad opposing-pistons with a 40mm bore, and the rears are dual opposing-pistons with a 36mm bore, and both front rear calipers are constructed from aluminum to save weight. The sheer size of this kit provides stronger braking performance through increase leverage and pad contact area, while the large rotors increase heat capacity, making these brakes hold up against brake fade longer on the track and on the fast roads.
The basic kit includes all parts necessary:
• Akebono 4-Piston Front caliper - standard in silver Infiniti
• Akebono 2-Piston Rear caliper - standard in silver Infiniti
• Custom Front caliper adapter w/ all necessary hardware
• Front & Rear Nissan OEM rotors
• Front & Rear Centric Posi-Quiet brake pads
• Front & Rear brake pad hardware with pins & clips
£1529
Optional:
Rotor
- drilled, slotted, drilled & slotted - FREE
- Stoptech E-Coat - drilled, slotted, drilled & slotted - £99
- Front: DBA 2pc 5000; Rear: DBA 1pc 4000 T3 - £599
Caliper colour
- 40th Anniversary Nissan red - £199
- Nissan grey - £199
- any other standard powder coating colour (black, red, blue, navy, white, yellow) - £279
- special powder coating single colour - £329
- special powder coating 2-Stage colour (gold and clear) - £429
Logo
- Akebono, Nissan, Infiniti - white or black - FREE
- Custom logo in any colour - £139
Pads
- Nismo - £99
- Hawk HPS - £119
- Project Mu type NS400 - £129
- Project Mu HC+ - £189
- Project Mu B Force - £219
- Project Mu Club Racer - £269
- Ferodo DS2500 - £299
Lines
- steel braided lines - £99
Fitting instructions
http://www.torqen.uk...tions_small.pdf
Wheel fitment templates
FRONT
REAR
Edited by octet@TORQEN
  • Like 2
  • 3 weeks later...
