I think its time for a replacement
dwallis
Hi all, i've got an '03 350z fairlady and it think its time the suspension was replaced because the ride is becoming a little uncomfortable, even the smallest bumps or level changes have me thrown about in my seat.
I've had the car for about two years but i am pretty much a n00b, so any advice or pointers would be greatly appreciated!!!
Should i replace the suspension?
If so, with what? The ride and handling are equally important to me, so OK handling with an OK ride are perfectly acceptable.
Where should i go for fitting?
Anything else i should be considering?
Thanks Y'all
Do you have a budget? Sounds like the shocks may be a bit tired, so some coilovers might be what you need. To be fair a lot of the bushes may be shot too, so just replacing the shocks and springs might not totally resolve the issue, but a good place to start.
Start by identifying what it is that's wrong with your suspension.
Get it up on a ramp or axle stands and give all the suspension a good push/pull/wwiggle. See if anything makes a grinding or banging noise.
Look for any obvious damage or broken parts. Check for oil leaks from the shocks.
Pointless spending £100s on parts that you may not need Or that may not fix the problem.
I've not really got a budget, because i'm not entirely sure what it is in need to do and what is actually wrong.....so as you all say, I'll get someone to have a look and assess the situation and go from there.
Thanks for the advice, i'd have just gone and got some new shocks or something.
Appreciate you taking the time! :teeth:
