snoged Posted January 19, 2015 Share Posted January 19, 2015 been away for a while just been looking to see if there was a definite "cure" for the boot pop up issue but cant seem to find anything. Has this been solved yet ? Quote Link to comment Share on other sites More sharing options...
jollyranchers Posted January 19, 2015 Share Posted January 19, 2015 I may be dreaming but is it me or does the cold weather make it worse ?!! same with the boot struts ! Try a sticky pad from pound shop on the popper , gives it more oomph You can get new heavy duty poppers on here , forget who sells them Quote Link to comment Share on other sites More sharing options...
GMballistic Posted January 19, 2015 Share Posted January 19, 2015 (edited) Remove boot weight. Add pennys/nylon washers to the inside of the boot poppers. Link: http://www.350z-uk.c...he-penny-trick/ Get new boot poppers. ^^ That's your options as far as I'm aware. Edited January 19, 2015 by GMballistic 1 Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted January 19, 2015 Share Posted January 19, 2015 Mine has been really bad for the last couple of weeks. I have put it down to the cold. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted January 19, 2015 Share Posted January 19, 2015 Gas struts make no difference to pop - only to staying open when it's up. The angle is just far too severe for them to help with pop. Sticky pads for the bottom of the springs work, though getting them to bond long term to the rubber is a PITA 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted January 19, 2015 Share Posted January 19, 2015 Gas struts make no difference to pop - only to staying open when it's up. The angle is just far too severe for them to help with pop. Sticky pads for the bottom of the springs work, though getting them to bond long term to the rubber is a PITA Yep good point, that is true. Quote Link to comment Share on other sites More sharing options...
richard.hezlett Posted January 19, 2015 Share Posted January 19, 2015 peteman35 reconditions them with uprated springs for £15 inc p&p all in or Clark Motorsport will sell you new ones for £30 each. Quote Link to comment Share on other sites More sharing options...
sipar69 Posted January 20, 2015 Share Posted January 20, 2015 Took the weight out of my Nismo boot. Worked for a day. Suppose next step is to get the springs replaced under warranty. Quote Link to comment Share on other sites More sharing options...
Zedd Posted January 20, 2015 Share Posted January 20, 2015 I took the weight out, plus the wiper delete so I also removed the wiper motor. Seems to work for now Quote Link to comment Share on other sites More sharing options...
brillomaster Posted January 20, 2015 Share Posted January 20, 2015 for the initial 'pop' you need either the penny trick (about 3p per side cured mine) or buy some new springs (expensive) for the lift and staying up, the struts definitely don't work as well when its cold out - in summer they're fine, but in winter the boot constantly tries to eat me. I'll be removing the bootlid weight this weekend, hopefully removing a kilo of weight from the very back of the boot will help! Quote Link to comment Share on other sites More sharing options...
glovermx Posted January 20, 2015 Share Posted January 20, 2015 Just out of interest, why is the weight in the bootlid there in the first place? i plan on removing mine soon. Quote Link to comment Share on other sites More sharing options...
Zedd Posted January 20, 2015 Share Posted January 20, 2015 Its so the boot closes, but in reality it trys to kill you everytime you stick your head in there Quote Link to comment Share on other sites More sharing options...
WINKJ Posted January 20, 2015 Share Posted January 20, 2015 Took the weight out of my Nismo boot. Worked for a day. Suppose next step is to get the springs replaced under warranty. Which is exactly what I am doing - suppose to be a fault - but the bloke at nissan also said that the month long wait for these poppers are because it's Nismo related.... Yep. Quote Link to comment Share on other sites More sharing options...
Mikeymike7 Posted October 22, 2015 Share Posted October 22, 2015 Penny trick has worked for me, brilliant I'm really pleased to not have to do that ridiculous balancing act again every time i open the boot. I used 3 pennies. Mike Quote Link to comment Share on other sites More sharing options...
brillomaster Posted October 22, 2015 Share Posted October 22, 2015 3 pennies a side worked a treat on mine! Still have to do a balancing act though - balancing the bootlid on your head on a cold day, lest it try and kill you! Quote Link to comment Share on other sites More sharing options...
Kaveney Posted October 22, 2015 Share Posted October 22, 2015 This Remove weight add plastic washers . Alan Remove boot weight. Add pennys/nylon washers to the inside of the boot poppers. Link: http://www.350z-uk.c...he-penny-trick/ Get new boot poppers. ^^ That's your options as far as I'm aware. Quote Link to comment Share on other sites More sharing options...
jimmy.farrow7 Posted October 22, 2015 Share Posted October 22, 2015 Penny trick worked a treat for me, no problems since Quote Link to comment Share on other sites More sharing options...
JetSet Posted October 22, 2015 Share Posted October 22, 2015 It's a very poor design, mine had this fault from new. Interesting that the HR roadster boot always pops first time. Pete Quote Link to comment Share on other sites More sharing options...
