RyanT Posted January 17, 2015 Share Posted January 17, 2015 Hi all, I've self-diagnosed the fuel damper as failing on my beloved 350. (ticking on idle, ticking stops once car is turned off/restarted (?) However, where do you suggest sourcing one from? Nissan want ~£175 and all of the decent other sources seem to be from the USA, eg: £41 here (+ £20 shipping): http://www.rockauto.co.uk/catalog/x,carcode,1433005,parttype,6120 Or £55 odd on eBay, plus £25 or so shipping/import charges. http://www.ebay.co.uk/itm/Fuel-Injection-Pressure-Damper-fits-2003-2006-Nissan-350Z-STANDARD-MOTOR-/291288318764?pt=Motors_Car_Truck_Parts_Accessories&hash=item43d223032c http://www.ebay.co.uk/itm/Fuel-Injection-Pressure-Damper-fits-2002-2006-Nissan-350Z-Murano-Maxima-S-/291277487630?pt=Motors_Car_Truck_Parts_Accessories&hash=item43d17dbe0e Has anyone had any luck with something similar to the above? Or should I just play it safe and get one from Nissan? Also, is there a risk of the damper causing any damage/suffering total failure? Or is it (at worst) just going to keep ticking as even the Nissan dealer says they don't stock them and it'll take a week or so to get one sent from Amsterdam. Many thanks in advance! Quote Link to comment Share on other sites More sharing options...
Jp606 Posted January 17, 2015 Share Posted January 17, 2015 Try Clark Motosport on here, they should be able to get hold of them. Quote Link to comment Share on other sites More sharing options...
Neilp Posted January 17, 2015 Share Posted January 17, 2015 How easy is it to change the fuel damper. Mines is a little bit noisy but nothing extreme. If its easy then I might just go ahead and change it Quote Link to comment Share on other sites More sharing options...
RyanT Posted January 17, 2015 Author Share Posted January 17, 2015 (edited) Try Clark Motosport on here, they should be able to get hold of them. Brilliant thanks, I'll PM them now! How easy is it to change the fuel damper. Mines is a little bit noisy but nothing extreme. If its easy then I might just go ahead and change it Yeah likewise, I figured if it's going to need replacing eventually I may as well do it now. From what I've read/seen it's actually a fairly easy DIY. EDIT: If anyone comes across this thread as a result of a search, I'll post this up in case it helps - The damper is highlighted in red It's probably worth getting that O-ring next to it as well: Edited January 17, 2015 by RyanT 1 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 17, 2015 Share Posted January 17, 2015 I would say any in line fuel damper intended for a similar system pressure would work, I think the main problem is because Nissan created an economy system by not having a return circuit, OK a lot of return systems also run a damper but the FPR seems to remove most of the noise from them, whereas the damper gets all the feedback pulses from both the pump and the injectors, so no wonder it gets noisy. Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 17, 2015 Share Posted January 17, 2015 Sent CS a PM on here, I'm sure he can help Quote Link to comment Share on other sites More sharing options...
evilscorp Posted January 17, 2015 Share Posted January 17, 2015 Don't know but you might want to change the one at the end of the fuel rail too while you have it apart? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 17, 2015 Share Posted January 17, 2015 Plenty pre owned in stock, just drop me a PM. Alex. Quote Link to comment Share on other sites More sharing options...
