Craigant Posted January 16, 2015 Share Posted January 16, 2015 one of my wheels has cracked and i cant find a single wheel so after a set of 19's for my 350. Cheers. Quote Link to comment Share on other sites More sharing options...
nissan nutter Posted January 17, 2015 Share Posted January 17, 2015 What sort of style are you looking for? What is your budget? Location might help as well Quote Link to comment Share on other sites More sharing options...
Del Posted January 17, 2015 Share Posted January 17, 2015 Hi. I have a spare set of 19's that removed from my 350. Matt Black (No kerb damage on outer rims) Usual wear and tear but nothing to shout about... Tyres are still on but worn out on inside as they were stretched. Only left them of for not to protect rims. Varrstoen Track ES200 19x9.5 ET22 Varrstoen Track ES200 19x10.5 ET22 Hub Size 73,1 5 x 114,3 I still have the bill of sale purschased in May 2011. Points to note: As they are offsett +22 they will not clear the brembos at the front so no issues if you dont have brembos.. If you do then you could run a spacer or shim to clear but you will still need to have enough bolt length left to attach wheel. I originally had 20mm spacer front and 25mm spacer rear but camber was adjusted to compensate with rear arch roll. Only other thing which was wierd is that the casting stamp on the inside off alloys says 5x120 ie BMW but they are not. They obviously forgot to change the cast stamp when they made them !! Anyhow I have pics with them on and off the car Looking for £500 ono... Thanks Derek Quote Link to comment Share on other sites More sharing options...
Ian Posted January 17, 2015 Share Posted January 17, 2015 On 17/01/2015 at 14:22, Del said: Hi. I have a spare set of 19's that removed from my 350. Matt Black (No kerb damage on outer rims) Usual wear and tear but nothing to shout about... Tyres are still on but worn out on inside as they were stretched. Only left them of for not to protect rims. Varrstoen Track ES200 19x9.5 ET22 Varrstoen Track ES200 19x10.5 ET22 Hub Size 73,1 5 x 114,3 I still have the bill of sale purschased in May 2011. Points to note: As they are offsett +22 they will not clear the brembos at the front so no issues if you dont have brembos.. If you do then you could run a spacer or shim to clear but you will still need to have enough bolt length left to attach wheel. I originally had 20mm spacer front and 25mm spacer rear but camber was adjusted to compensate with rear arch roll. Only other thing which was wierd is that the casting stamp on the inside off alloys says 5x120 ie BMW but they are not. They obviously forgot to change the cast stamp when they made them !! Anyhow I have pics with them on and off the car Looking for £500 ono... Thanks Derek Any pics? If hes not interested I definitely am Quote Link to comment Share on other sites More sharing options...
Del Posted January 17, 2015 Share Posted January 17, 2015 I have included below the link for photobucket for pics of wheels. Included in the pics is the part copy of invoice showing listed items and a pic of car when they were on. http://s1375.photobucket.com/user/derekjohnson/slideshow/Wheels Thanks Quote Link to comment Share on other sites More sharing options...
Spatt Posted January 19, 2015 Share Posted January 19, 2015 nice wheels ! im interested in these Matt Quote Link to comment Share on other sites More sharing options...
Del Posted January 19, 2015 Share Posted January 19, 2015 Hi Matt Craigant asked about my location but not heard nothing back. Ian was next on the list but not heard anymore.. Maybe there locations dont know.. Anyhow based in Essex and the wheels are still available for collection..... Dont want to post as they will just get damaged. As i originally noted tyres worn out on inside so they would more than likely need replacing.. Regards Derek Quote Link to comment Share on other sites More sharing options...
