Rear axle align and adjust. (Advice please.)
veilside z
Hi all, does anybody know if there is a kit to re adjust the rear axle so the hub can be RE set to centre of wheel arch. I know there are camber kits out there but not what we need. Basically, what we see at present is a lowered 350 running 20" wheels, and when you look at the car from the side view, the rear wheel is nearly touching the arch nearest to door, but the rear of arch where mudflap can go, a wide gap. Im thinking smaller dia wheels and raise car, or modify arch? Ideally wheel hub needs shifting 50mm backwards direction rear bumper. All help greatly appreciated. Thank you
