NigelB Posted January 15, 2015 Share Posted January 15, 2015 My drivers window does not shut correctly goes up and drops been told there is a switch inside the panel which needs to be reset how do you get the panel off to get to it and what do you do to the switch Quote Link to comment Share on other sites More sharing options...
Will370z Posted January 15, 2015 Share Posted January 15, 2015 http://www.350z-tech.com/wiki/index.php?title=TSB_04-089_Window_Regulator_Motor_Reset_Procedure Quote Link to comment Share on other sites More sharing options...
TimC Posted January 15, 2015 Share Posted January 15, 2015 Also there is a good guide on how to repair the motor written by a member http://www.350z-uk.c...ic-windows-pdf/ which describes how to dismantle the door panels. I had trouble with mine and I think it was because the window was not dropping quick enough as I opened and closed the door and sometimes it was catching. Had to do reset 3 times in 2 months, its OK now but the window does not go up quite as high as before so that may be why. Quote Link to comment Share on other sites More sharing options...
