SPACERS?!
BJRz
Hello everyone,
Just in need of a bit of advice really...
I've recently purchased some H&R spacers from forum member - 20mm & 25mm...
the 25mm spacers on the rear fit fine... the wheels don't, but thats another story!! :headhurt:
However this is what the fronts look like...
I know the photos aren't brilliant and correct me if i'm wrong but arent the spacers, hub and the wheel all supposed to sit flush??
Basically the bolts from the hub are too long for the spacer and they come out the other side and hit the back of the wheel.
will a pair of these in between the spacer and the wheel fix this?
http://www.ebay.co.uk/itm/5mm-ALLOY-WHEEL-SPACERS-SHIMS-SPACER-UNIVERSAL-4-AND-5-STUD-FIT-/271073295602?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item3f1d3a3cf2
Thanks in advance! :thumbs:
No don't get any more spacers.
What wheels are you running, I'm guessing not rays.
You can either sheer off the hub bolts like I did, or ( I found out this weekend, don't know if you can on the zed) But thread the hub bolts further into the hub.
The spacers aren't incorrect, it's the wheel design.
im going to guess the aftermarket wheels dont have deep enough recess for the threads to go into
three choices;
bigger spacers (maybe switch the 25mm to front and 20 rears, if your rears are poking to much
other choice is new wheels
Or just dont run spacers
What width and offset are the wheel fitted?
Edited by StevoD
Thanks for the replies :thumbs:
I've just bought a set of used Rota D2's - 18 x 9, ET22 on the front & 18 x 10 ET 15 at the rear
The front's have 20mm spacers on (which are now 25mm due to the gap!) :dry:
The rears have 25mm spacers which fit perfectly.
I may have to take Grundy's advice and sheer off 5mm on the front
so currently ET-3 on the front and ET-10 on the rear is believe?
Alignment isn't sorted yet although I will be running a bit of camber.
There is no recess on the back of the wheel at all... they're completely flat.
I know I might have to ditch the spacers or swap them out for some smaller ones.. but I quite like how she sits at the moment :D
The rear arches are rubbing a lot at the moment so that's something i'm currently trying to sort out!
Here are a few pictures:
Not 100% on gold wheels on a GM 350z, so that may change. Although they are growing on me!
Yes she hasn't had a wash in a while and it won't be to everyone's taste...
Feedback welcome!! :lol:
try putting the 25mm on the front and 20mm on the rear
Yeah I think I may have to give that a go as it may sort out my clearance issue on the rear arches. although I think I'll still have the same issues with the gap between the spacers and the hub :(
Nice wheels, the gold looks good IMO. Did you buy off them off a guy named Paul?
Yeah I think that was his name?
Lives in Mildenhall?
Yeah that's him, he had them on his black 350.
Yeah he had his Zed parked outside, was rather nice B)
I forgot to ask him what wheels he was opting for next!
Is he a member on here?
Mmmm cant offer any help on the spacers, but liking the look of the wheels on a Gunmetal zed, think that sits really nice as it is! also like the single exit exhaust, bet that's loud!
Thanks mate :thumbs:
Yeah initially I wasn't a fan of the gold and didn't think it'd look that good, although now they're on the car I don't think they look too bad!
hahaha well lets just say I'm not very popular with the neighbours... :teeth:
It does sound amazing though, once the weather clears up and i've sorted the fitment on the wheels i'll try and get some videos up :drive1
He was planning on selling his car but not sure what his plans are now. No, told him to join but he hasn't
Are you sure Grundy ;)
Pretty sure :)
