Engine pre-heater
addario
Coolant gets warm quickly, that's not the issue here. The problem is that the oil will still be stone cold, and that's what causes the wear.
they do have a temperature equaliser its the square bit that the oil filter is fitted to you will notice two water pipes on the side of it problem is no oil flow so you heat up about a cups worth.
