sy8ts Posted January 5, 2015 Share Posted January 5, 2015 Folks, having a slight issue again!!!! Radio sorted though Todays issue is that my engine management light keeps coming on, ive had it hooked up to the computer & reads no error, reset the ECU, Yet the light keeps coming on?? Any ideas ??? I haven't changed anything from stock, Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 5, 2015 Share Posted January 5, 2015 Have you tried checking the brake fluid level...its a classic for CEL with no apparent reason. 1 Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 5, 2015 Author Share Posted January 5, 2015 Ah not checked that, I'll check all the levels tomorrow, only thing I have checked is the oil, I take it if after I do top everything up I'll have to reset the ecu again? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 5, 2015 Share Posted January 5, 2015 No mate it will go off without, if its indeed the brake fluid. Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 6, 2015 Author Share Posted January 6, 2015 Nope brake fluid level is fine, all levels are good,,, Tried to reset the light again & now it wont go off Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted January 6, 2015 Share Posted January 6, 2015 Is the CEL on constant or flashing? Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 6, 2015 Author Share Posted January 6, 2015 Its on constantly, I can switch it off by going through the pedal sequence, ive hooked it up to the computer too & reads no fault, yet the light appears again, the car has been sitting for a good while, started weekly though & and has had a good run, fresh petrol etc. Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 6, 2015 Share Posted January 6, 2015 What type of code reader are you using? If it's a cheapy you might be better getting a more advanced scanner on the job. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 6, 2015 Share Posted January 6, 2015 Its on constantly, I can switch it off by going through the pedal sequence, ive hooked it up to the computer too & reads no fault, yet the light appears again, the car has been sitting for a good while, started weekly though & and has had a good run, fresh petrol etc. Is your Z a JDM model? some code readers that can read JOBD cannot access the various modules as well, so don't see the codes from these. Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 6, 2015 Author Share Posted January 6, 2015 UK spec 2005 model 57,000mls, using Bosch diagnostic reader Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 14, 2015 Author Share Posted January 14, 2015 Folks I'm reading a code P0037 H02s heater control, circuit low, bank 1 sensor 2? What does this mean and how can I fix it? Does it effect performance? Quote Link to comment Share on other sites More sharing options...
gsexr Posted January 14, 2015 Share Posted January 14, 2015 let me google that for yer http://www.obd-codes.com/p0037 Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 14, 2015 Share Posted January 14, 2015 It's the heater element of the O2 sensor (brings the sensor up to temp quicker when cold). Bank 1 I think is driver side (whichever side cylinder 1 is on) and sensor 2 is the furthest away from the engine (the post cat sensor in this instance). Swap out the sensor for a new one. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted January 14, 2015 Share Posted January 14, 2015 Yep, the link above pretty much tells you all you need to know and how to go about fixing it. It won't cause any damage or have any noticeable effect on how the car drives in the short term, so don't panic. For reference: The (bank 1 sensor 2) Sensor it relates to is fitted in the rear of the driver's side CAT. Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 14, 2015 Author Share Posted January 14, 2015 Perfect thanks for your help folks, would that be why I sometimes hit a flat spot in the revs when flooring it? Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 14, 2015 Share Posted January 14, 2015 Perfect thanks for your help folks, would that be why I sometimes hit a flat spot in the revs when flooring it? Unlikely I'd say. It should only really come into effect when the engine is cold until exhaust temps ramp up. Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 15, 2015 Author Share Posted January 15, 2015 Bugger, ill have to have the flatt spot looked into, cars been off the road for a while, any remaps suggested or chips? Quote Link to comment Share on other sites More sharing options...
martybhoy Posted January 15, 2015 Share Posted January 15, 2015 Wasn't aware of the brake fluid problem... good to know! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 15, 2015 Share Posted January 15, 2015 Perfect thanks for your help folks, would that be why I sometimes hit a flat spot in the revs when flooring it? No the cat monitor O2 sensor is only used under certain circumstances and is not used during normal running, they can actually be removed with no detrimental effects, mine ran fine without them as I swapped mine out for wide band monitors. Quote Link to comment Share on other sites More sharing options...
sy8ts Posted January 16, 2015 Author Share Posted January 16, 2015 Bloody hell!!! Jacked the car up today and had a look, somebody has actually snipped the wires!!!!!! Both sides,!, don't know how long it's been like this as it been off the road for a few years and been in storage, Why the hell would anybody do that? It's surely been like that since I bought it, I bought the car tested in 2010 with mot, moved away n stored the car I a secure warehouse, so wasn't done there, Laugh is I just had it tested and it sailed through as the emissions machine was broke that day, I'm a bit concerned now though as this could have been done for god knows what reason , on the plus side, it doesn't use oil, water or anything else and is low miles, just can't understand why 1 somebody would do this & 2nd what effect it's had, On another note, why won't this site let me post pics? I've tried to upload ones I've taken with my phone and it won't let me, says they are to large? Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted January 16, 2015 Share Posted January 16, 2015 Upload photos elsewhere, like photobucket, and the link to them. Hosting the photos here would cost too much. 1 Quote Link to comment Share on other sites More sharing options...
