HAMLNJ Posted January 2, 2015 Share Posted January 2, 2015 Hi, needs some help. I have had some knocking coming from the rear of the car (I think it's the rear) started off a very light knock, now getting worse. It's only at low speeds and happens on slightly rough roads. It also stops when I'm braking!? So I took it down to my garage, they noticed that my front control arm bushes are a little worn, once siege pretty work and loose, but nothing bad. Going to get these changed. And the rear anti roll bars are slightly worn so doing them same with these. Worth changing to Polly pushes? Anyway, they are not sure if that is the problem. We have a crow bar on every joint and moving part and nothing would make this noise...until...... We gave the rear axel a shake and this made this knocking noise. It's not making the notorious clicking noise but a thuddy slight knock. Is this the problem? Anyone had the same issue? Car has been around the world a few times with a total of 112k on the clock. But looked after with a very good full service history. As for the warning part of my subject, don't buy those cheap silenced decats, found both are blowing. With 11months of being on. Thanks guys Ian Quote Link to comment Share on other sites More sharing options...
Jp606 Posted January 2, 2015 Share Posted January 2, 2015 Could be drop links, they are known to fail. Remove the one on the offending side and (carefully) drive round the block to see if the noise has gone. If it's the front then it's most likely the banana arm bushes or ball joint (compression arm). When these fail you get a knock that usually goes when you brake, however it's at the front rather than the rear. They are almost impossible to diagnose by using traditional methods of moving components with a bar etc. 1 Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted January 2, 2015 Author Share Posted January 2, 2015 Cheers buddy, I'll show your reply to my garage tomorrow. Doing that test drive without the part sounds like a plan Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 2, 2015 Share Posted January 2, 2015 Definitely the same sort of noise a failed ARB droplink would make. That said I had a similar noise under similar circumstances, changed the links and it did bugger all. 1 Quote Link to comment Share on other sites More sharing options...
370Ad Posted January 2, 2015 Share Posted January 2, 2015 Cheap decats as in 2fast2cool on ebay Sorry to hear about your problems bud. Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted January 2, 2015 Author Share Posted January 2, 2015 On 02/01/2015 at 20:24, 370Ad said: Cheap decats as in 2fast2cool on ebay Sorry to hear about your problems bud. It's ok, I bought them from ryan on fire? I expect they all come from the same place in china. Now i have the scorpion I'm going to put my cats on for now and add a y pipe. When I have a few quid I'll get some HFCs. For the knocking it gives me a chance to change things to Polly bushes. Also putting new discs and pads, changing the gear box oil, diff oil and an engine service. Putting some tein springs on too. All good tlc!! Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted January 2, 2015 Author Share Posted January 2, 2015 To be fair I have contact the seller about these decats, even though it's only 100 they should last more than 11 months!! Quote Link to comment Share on other sites More sharing options...
370Ad Posted January 2, 2015 Share Posted January 2, 2015 Ryan on fire, 2fast2cool and Japspeed all seem to be the same. Should definitely last longer than a year! Quote Link to comment Share on other sites More sharing options...
