aspire5315 Posted December 31, 2014 Share Posted December 31, 2014 hi everyone, looking for a little help, on picking up my zed from the forecourt i insisted on a new fan and aircon belt, these were fitted and i took car away, i have noticed a squeak as if the fan belt is slipping noise goes after a couple of seconds but its anoying to say the least! only on cold start up..... i have it booked into nissan this friday but was wondering if this could be rectified by myself at home?, any help please Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted December 31, 2014 Share Posted December 31, 2014 There are two belt tensioners you can access below the enginebay , or if it's a momentary squeak, maybe use some talcum powder 1 Quote Link to comment Share on other sites More sharing options...
benjy88 Posted December 31, 2014 Share Posted December 31, 2014 Recommend the taIc powder as weII! Worked on mine Quote Link to comment Share on other sites More sharing options...
aspire5315 Posted December 31, 2014 Author Share Posted December 31, 2014 where do you put the talc exactly? from under the bonnet on top of the engine? where the belt is or on the pulley Quote Link to comment Share on other sites More sharing options...
spoorsy Posted December 31, 2014 Share Posted December 31, 2014 personally i would take the extra time to jack the car up and just add a little more tension to the pulleys. Literally takes 10 mins. I had the same issue when i fitted the new ac and aux belts on mine, fine for a few days then started squealing becasue they had stretched slightly. For what its worth sort it properly, im sure there is a thread on here about it Quote Link to comment Share on other sites More sharing options...
aspire5315 Posted December 31, 2014 Author Share Posted December 31, 2014 yep found the thread, thanks! but im not confident in my mechanic skills so its booked into nissan friday...... at least i can talk as if i know what im on about as the guy behind the service desk said they were self tensioning.......... Quote Link to comment Share on other sites More sharing options...
spoorsy Posted December 31, 2014 Share Posted December 31, 2014 yep found the thread, thanks! but im not confident in my mechanic skills so its booked into nissan friday...... at least i can talk as if i know what im on about as the guy behind the service desk said they were self tensioning.......... if you were closer i would have showed you how to go about doing it, glad you found the guide tho. yep, i wouldnt believe a word the service desk guy says... all the best for 2015! Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted January 1, 2015 Share Posted January 1, 2015 If you can't do the belts then I'm afraid you have No mechanics skills , its easy the thread is spot on the adjustment will take 10 minutes it's getting to the adjustment that will take a little longer be interested how much your going to get stung for this Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted January 1, 2015 Share Posted January 1, 2015 To get to the adjusters only requires the plastic Undertray to be removed. Unless you have an aftermarket Z-Speed one, which will be even quicker Quote Link to comment Share on other sites More sharing options...
350zedd Posted January 1, 2015 Share Posted January 1, 2015 If you have any talc over, you can use it on your armpits and bits!! 1 Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted January 1, 2015 Share Posted January 1, 2015 Getting the undertray off is easy if you know your car and the z speed will be quicker, but if it's not been off regular then there may well be broken bolts and cable ties then there's also getting the car up enough to get under either way first time is not straight forward, Quote Link to comment Share on other sites More sharing options...
aspire5315 Posted January 1, 2015 Author Share Posted January 1, 2015 well with no axle stands and jacks its a non starter for me, Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted January 1, 2015 Share Posted January 1, 2015 (edited) I've got the same issue, it only makes a noise in the cold weather and only for a minute or two after start up. I've just had the belts changed. I would like to know more about this talc method! I can see trying to get the talc just on the grooved side of the belt would be an issue. Wouldn't WD40 do the trick. Edited January 1, 2015 by Randy_Baton Quote Link to comment Share on other sites More sharing options...
evilscorp Posted January 1, 2015 Share Posted January 1, 2015 Don't even need the undertray off, you can fit your arm down behind the radiator and in front of the engine and tighten from there, even with supercharger piping in the way (just involves some blood loss usually from my knuckles.) Quote Link to comment Share on other sites More sharing options...
aspire5315 Posted January 2, 2015 Author Share Posted January 2, 2015 all done, a free inspection and levels checked, belts tensioned 2 free coffees, a total of £20.16p pleasantly chuffed if i dont say so my self, howards nissan in weston super mare..... Quote Link to comment Share on other sites More sharing options...
aspire5315 Posted January 3, 2015 Author Share Posted January 3, 2015 If you can't do the belts then I'm afraid you have No mechanics skills , its easy the thread is spot on the adjustment will take 10 minutes it's getting to the adjustment that will take a little longer be interested how much your going to get stung for this £20.16p for letting someone else get dirty 1 Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted January 3, 2015 Share Posted January 3, 2015 Quote Link to comment Share on other sites More sharing options...
