New Rims! Have a guess..
MCook
Big reveal will be tomorrow... that is if all goes to plan.
Some hints...
18"
Rears Width 10.5
Rears Offset ET5
Front Width 9.5
Front Offset ET15
I believe I will be the first Zed with these wheels, have not seen another with them (they are also new on the market I think..)! Off to get tyres and all that jazz tomorrow, hopefully they will fit just fine!
what size tyres you plannlng to run.?
Not sure.. what would you recommend? Open to suggestions! Im planning to go to the wheel specialist Farnham tomorrow..
Standard suspension?
Yes :headhurt:
Do you plan on lowering in the future?
Yes :headhurt:
Potentially yes
Yes :headhurt:
Potentially yes
Ok, then I'd suggest you go for 265/40 rears, 245/40 front. The usual for 10.5" rims in 275 but because of the aggressive offset of the rear wheels, I think you'll need a little more stretch than normal. You'll get away without rolling the arches until you lower it I think, but lets just hope they fit over the callipers for now :D
There are people more clued in than I am with regards to wheel/tyre combo's on the 350, so wait until one of them come along to confirm :thumbs:
^^ What Kyle said seems right. My guesstimate would have been;
Front: 245/45/18
Rear: 275/45/18 (although a 265 makes sense if it will help avoid rubbing)
But possibly a 40 profile might be needed on the front/rear? as Kyle suggested. Need to be careful you get the rolling radius correct so you don't get any TC issues. ;)
Edit: Mistake.
Edited by GMballistic
hope this helps you in your choice......
i am currently running on tein super street coilovers at about a 50 mm drop with rolled rear archs ......front wheels 9.5j with 235/40/18 tyres with et 20 +15mm spacer =et5..rear wheels 10.5j with 255/40/18 tyres with et20 +15mm spacer =et5....as you can imagine the rears have a slight stretch but i could get away with a 0 et on these tyres ;)
10384844_10204624401282957_2567261213719549544_n.jpg?oh=ff7c318f158a7062dcbe9f5d8e07c250&oe=5540D1C7&__gda__=1429940945_6e1b24a6a5c13f947ae66b20002b884f
10393775_10204624401882972_5482643103140854079_n.jpg?oh=897255e5a365ca81747040e030db129c&oe=5531BDE7&__gda__=1430085762_20e877e277654e5b9f5b287e135afa60
10881559_10204624402682992_8464135844311702788_n.jpg?oh=752cc1cfd3d2ac76354353f93f286c2f&oe=553C18BD
suspension has now settle down after wheels being fitted. :teeth:
