Adrian@TORQEN Posted December 29, 2014 Share Posted December 29, 2014 (edited) ARK GRiP True Dual Exhaust System Burnt Tip The ARK "GRiP" exhaust system provides the serious enthusiast a combination of sound, style, and quality craftmanship. As a leader and innovator in aftermarket exhaust systems we are highly recognized for our exclusive designs, proven HP/Torque performance gains, and our significant ARK exhaust note sound that is resonant, pure, rich, and deep. All of our exhaust systems is constructed with only high quality premium materials using state of the art equipment and technology. At ARK Performance we invest most of our time in research and development in such areas as exhaust gas flow, piping size, back pressure, inner core structure, fitment and sound by our finest engineers in the automotive industry.
 With our passion, dedication, experience and knowledge about cars, racing, and lifestyle we bring you the finest exhaust systems like GRiP, DT-S, and N-II. ARK Advantages and Features: • All Bolt-On System • Helmholtz Design for Minimized Drone • Burnt Tips • SUS304 Stainless Steel Construction • Fully Polished Finish, 2.5 inch Dual Piping • CNC Machined Flanges • Exposed Micro TIG Welded Items Included: Axle-back Muffler, Mid-pipe, X-flow Y-pipe with resonator, Bolts, Gaskets, Hardware £1199 Invidia Gemini Rolled Titanium Tip Cat-Back £845 Berk Technology Dual Exhaust System £1199 Injen Dual 60mm SS Cat-Back Exhaust Resonated £1149 AAM Competition 3" True Dual Exhaust System £1399 AAM Competition 370Z 2.5in True Dual Exhaust £999 Akrapovic ME-NI/SS/1 Titanium Evolution Exhaust £1899 Greddy Spectrum Elite SE Exhaust £1349 Stillen 370Z Dual Cat-Back Exhaust System £1199 HKS Catback Exhaust System - Hi-Power Stainless Steel Titianum Tip £1699 ARMYTRIX Nissan 370Z Super Sport Valvetronic Exhaust System Mid pipe + Valvetronic muffler + Wireless remote control kits + Dual chrome silver tips + Race Y pipe + High-flow performance de-catted down pipe with cat simulator £2349 GT Haus MeisterSchaft Exhaust System GTHAUS Meisterschaft GTS Round Split SS Exhaust + SS Straight Cat-Back Mid Pipe + SS Front Y-Pipe Collector Section £2199 ARK R-Spec Test Pipes £529 Berk Technology Metallic Substrate High Flow Cat £399 Berk Technology Test Pipes £199 370z Motordyne Advanced Resonance Tuning - ART Test Pipes Through countless hours of research and development a new path has been explored in the never ending quest for performance. A method of directly altering exhaust harmonics for enhanced performance and sound, this is Motordyne's debut of the patent pending Advanced Resonance TuningTM. 15 to 20 Ftlbs more low end torque than conventional test pipes. ART pipes increase power and torque without the drastic increase in loudness normally associated with test pipes. These provide the quietest, smoothest, deepest sound while greatly reducing or eliminating rasp and drone. The difference in sound is not subtle. They're not conventional test pipes. They're ART pipes! 2 week lead time. Compatible with 2WD automatics. Not compatible with AWD vehicles. £529 370z DC Sports Headers Ceramic DC Sports is pleased to introduce its all-out performance headers (part number NHS4202). With power gains of up to 12.4 horsepower and 11.2lbs/ft of torque with our headers, these bolt-on power adders are a must. DC Sports header and exhaust systems are dyno tested to outperform all comparable header systems on the market. Extensive research and development goes into each system to ensure the best fit, finish and performance for your vehicle. DC Sports header and exhaust systems are precision bent on our CNC mandrel benders using data acquired from our non-contact digitizing scanner. DC's flanges are CNC machined, we attach the flange to the header pipes, then machine-grind the flange-mating surface to ensure a leak-free seal. Our state-of-the-art manufacturing process ensures superior quality and a perfect fit with every header system DC make. Header System Key Features: • Every system is dyno-tested for maximum performance • CNC mandrel bends with precision-welded fittings deliver perfect fit • CNC-machined flanges eliminate leaks. • Equal length primary piping ensures optimum tuning of systems for more power across rpm range • C.A.R.B. exempt or pending C.A.R.B. exemption • Beautiful brushed finish Includes comprehensive instructions and all necessary hardware £449 370z Stillen Ceramic Coated Headers The STILLEN Z Headers are the finest available. With months invested in development work, these headers produce big increases in streetable power and torque on both naturally aspirated and forced induction vehicles. The equal length design of the headers allows better and more efficient exhaust scavenging which contributes to the dyno tested performance gains. Examples: - 2004 350Z produced 11.5 hp at @ 6200 RPM and 18.5-lb.ft @ 3800 RPM at the wheels - 2008 370Z Coupe produced 14.5hp at @ 7300 RPM and 12.5 lb-ft @ 4200 RPM at the wheels With STILLEN's 20 years of experience in designing and manufacturing Nissan performance parts, you should have complete confidence that every STILLEN product is of the highest quality and has under gone extensive research and development before production. STILLEN manufactures our high performance headers from varying materials according to application parameters. All of our uncoated headers are stainless steel for long life and corrosion resistance. Our ceramic coated headers are for those who want an additional thermal barrier to lower engine bay temperatures as well as excellent stain and rust resistance. These hand crafted shorty headers do not require the removal of the catalytic converters. Headers are available in the following materials: 304 Stainless Steel - Maximum oxidation and corrosion resistance, excellent shine 409 Stainless Steel - Excellent corrosion resistance, may develop light surface discoloring Ceramic Coated - Provides a thermal barrier which reduces radiated heat into the engine bay, excellent stain and rust resistance Installation should be done by a qualified mechanic with proper tools and a lift. This is not a backyard bolt on. These headers do not remove the cats. Complete the performance upgrade with STILLEN's new race pipes. £629 370z Stillen Stainless Steel Headers The STILLEN Z Headers are the finest available. With months invested in development work, these headers produce big increases in streetable power and torque on both naturally aspirated and forced induction vehicles. The equal length design of the headers allows better and more efficient exhaust scavenging which contributes to the dyno tested performance gains. Examples: - 2004 350Z produced 11.5 hp at @ 6200 RPM and 18.5-lb.ft @ 3800 RPM at the wheels - 2008 370Z Coupe produced 14.5hp at @ 7300 RPM and 12.5 lb-ft @ 4200 RPM at the wheels With STILLEN's 20 years of experience in designing and manufacturing Nissan performance parts, you should have complete confidence that every STILLEN product is of the highest quality and has under gone extensive research and development before production. STILLEN manufactures our high performance headers from varying materials according to application parameters. All of our uncoated headers are stainless steel for long life and corrosion resistance. Our ceramic coated headers are for those who want an additional thermal barrier to lower engine bay temperatures as well as excellent stain and rust resistance. These hand crafted shorty headers do not require the removal of the catalytic converters. Headers are available in the following materials: 304 Stainless Steel - Maximum oxidation and corrosion resistance, excellent shine 409 Stainless Steel - Excellent corrosion resistance, may develop light surface discoloring Ceramic Coated - Provides a thermal barrier which reduces radiated heat into the engine bay, excellent stain and rust resistance Installation should be done by a qualified mechanic with proper tools and a lift. This is not a backyard bolt on. These headers do not remove the cats. Complete the performance upgrade with STILLEN's new race pipes. £689 370Z Top Speed Stainless Steel Headers This is the single most significant power modification for a non-turbo Z car (short of nitrous). Expect an increase in horsepower throughout the RPM range with the greatest gains at higher RPMs. The car remains driveable and noise level is not increased. Features Mandrel bends, T-304 stainless steel, Dyno tested design. Benefits: Optimum flow characteristics, long life and excellent heat dissipation, expect up to 12-16 rear wheel horsepower. £529 370z Motordyne Shockwave E370 Cat-Back Exhaust System The Shockwave))) E370 is a True Dual X (TDX) exhaust design of a modular nature for integration of different and evolving sounds and features. Fabricated entirely of stainless steel and designed for maximum power gains by using a combination of dual 2.5" and dual 3.0" stainless steel tubing. Dual 2.5" diameter primary tubes of the XYZ pipe inlets are optimized for diameter and length to yield maximum low end to upper midrange power and torque. Dual 3.0" exhaust tubes from the midpipe muffler on back are used to route the exhaust flow to the back of the vehicle for minimizing flow resistance and yielding maximum high RPM power.. The progressive expansion of tube diameter and exhaust flow area optimizes pulse scavenging while minimizing flow resistance and pressure drop. The result is maximum power and torque for NA and FI applications up to 700 HP. When used with the Motordyne ART test pipes the complete system design starts at dual 2 1/4 inch diameter at the ART pipe inlet and progressively expands to dual 3" flow tubes. Dual 2.25" diffused to dual 2.5" and then diffused to 3.0". This design provides the highest performance with an unusually powerful and low pitch exhaust tone. Hand crafted to the highest level of quality. Entirely TIG welded and deeply polished Stainless Steel 304L. Comes with your choice of 4.5" or 5.0" exhaust tips in Stainless Steel or burnt Titanium with either a straight or rolled lip. The tips are adjustable they can be pushed in or pulled out for different looks. They are also easily changed out for another set. £1599 370z DNA Stainless Steel Catback Exhaust System with Burnt Tips Upgrading vehicle's exhaust system is a great way to build horsepower, free up trapped torque, and improve upon restrictive factory systems. The larger pipes, low-restriction mufflers, and tuned resonators of a well-designed performance exhaust system can make a world of difference on your vehicle. The net result is lower auto exhaust backpressure, more horsepower, more torque, and a much better sound. Made of High Quality T-304 stainless Steel. TIG welded CNC machine flange for resistance against pressure and corrosion. Aggressive deep and smooth tone sound while ensures smooth exhaust gas flow. Increase engine output and efficiency. Muffler Tip Type: Dual Path Rounded Tip. Tip Diameter (IN): 4.5". Silencer Included. £649 Edited April 2, 2015 by octet@TORQEN Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted December 31, 2014 Author Share Posted December 31, 2014 More option added, photos to follow. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted December 31, 2014 Author Share Posted December 31, 2014 Photos added too. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 7, 2015 Author Share Posted January 7, 2015 ARMYTRIX Nissan 370Z Super Sport Valvetronic Exhaust System added in the first post. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 7, 2015 Share Posted January 7, 2015 Nice Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 7, 2015 Author Share Posted January 7, 2015 PM us if you need an exhaust system that is not listed here. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 7, 2015 Author Share Posted January 7, 2015 GT Haus MeisterSchaft Exhaust System added in the 1st post. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 6, 2015 Author Share Posted February 6, 2015 More options added, we will have description and photos added soon, once the photos have been watermarked. Quote Link to comment Share on other sites More sharing options...
The Bodyman Posted February 19, 2015 Share Posted February 19, 2015 Hi there. Whats would be the delivery charge to OX10 6RR for the: Invidia Gemini Rolled Titanium Tip Cat-Back Thanks Jonathan Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 19, 2015 Author Share Posted February 19, 2015 Hi, Delivery is included in the price. Adrian Quote Link to comment Share on other sites More sharing options...
The Bodyman Posted February 20, 2015 Share Posted February 20, 2015 Thanks Adrian. I will place an order with you a soon as I can. Jonathan Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 20, 2015 Author Share Posted February 20, 2015 Hi Jonathan, No problem, just PM us when you're ready to go ahead. Adrian Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 24, 2015 Author Share Posted February 24, 2015 More photos added, more exhaust options to come soon: MotorDyne Shockwave 2, Amuse Titanium, M7 etc Quote Link to comment Share on other sites More sharing options...
nrenz123 Posted February 24, 2015 Share Posted February 24, 2015 Do you have the invidia in stock? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 25, 2015 Author Share Posted February 25, 2015 More photos and options added. Quote Link to comment Share on other sites More sharing options...
gstraw Posted August 22, 2015 Share Posted August 22, 2015 Hey Adrian. From.the text it seems that changing the headers on the engine would give more horsepower than spending that cash on a full exhaust. Is this the case? I've got a stock exhaust with hfc and I like the noise and how there is no drone at motorway speeds. So if I want more power out of the car would you recommend the stock exhaust with new headers? Sent from my KFTHWI using Tapatalk Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 22, 2015 Author Share Posted August 22, 2015 Hey buddy! Expensive or time consuming job to replace manifolds, unless they're cracked or you have the engine out for some particular reason. To be quite honest, it's not a lot of gain from replacing the exhaust on it's own, specially without remap. Maybe with some Long Headers we're talking a different story 1 Quote Link to comment Share on other sites More sharing options...
gstraw Posted August 24, 2015 Share Posted August 24, 2015 Can you get the top speed exhaust? It sounds nice on videos and people say it's very well priced. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 24, 2015 Author Share Posted August 24, 2015 Yes, but it's a cheap exhaust, quality wise, you get what you pay for... Quote Link to comment Share on other sites More sharing options...
gstraw Posted August 25, 2015 Share Posted August 25, 2015 Oh really? Seen decent reviews in the USA forums. Some said its better than cobra with regards to sound? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 25, 2015 Author Share Posted August 25, 2015 If you ask me, good quality exhausts start from Invidia Gemini above... Anything else below it's just false economy Quote Link to comment Share on other sites More sharing options...
chrislich Posted September 24, 2015 Share Posted September 24, 2015 Do you know of anyone buying the dna exhaust? How loud is it? I'm not looking for stupid loud just a nice tone but not all the time only on trying Quote Link to comment Share on other sites More sharing options...
garygttdi Posted January 29, 2018 Share Posted January 29, 2018 Who can I go to fit one of your system to a 370 nimso please would like separated tunes .? Quote Link to comment Share on other sites More sharing options...
