luciiifer Posted December 29, 2014 Share Posted December 29, 2014 I have a Tach adapter from Autometer, does anyone know how to wire it? With that im going to run my windowswitch from JEGS.com. The windowswitch can be set to, 2,4,6 or 8 cylinders. So my question is, can i just cut the wires of 2 coils? or do i have to cut all the 6 coils to get the right signal? And it is enough with 2 coils, wich coils? Link to the windowswitch were you can look at the manual.: http://www.jegs.com/i/JEGS+Performance+Products/555/40824/10002/-1 And the Tach adapter: http://www.autometer.com/tach-adapter.html Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 29, 2014 Share Posted December 29, 2014 I strongly suspect that you will encounter problems, IE triggering CELs if you try and splice into the coil feeds as they are part of the CANbus system. Quote Link to comment Share on other sites More sharing options...
