Madhatter Posted December 23, 2014 Share Posted December 23, 2014 Hi all Car has developed a Christine type personality and has decided that while there is battery it's going to flash the hazards all day long with no chance to turn them off. Checked switch and all fine - in fact if I disconnect the switch altogether it makes no difference they still flash! Do I need an exorcism on the car or any ideas where to hunt for the problem? Any help so so appreciated as I'm at the end of my tether Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 23, 2014 Share Posted December 23, 2014 If memory serves correctly I think the Body Control Module (BCM) controls the indicators, not sure about the hazards but likely I guess. BCM's are known to fail unfortunately. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 23, 2014 Share Posted December 23, 2014 BCM also controls hazards....oh for the good old (cheap) indicator relay. Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 23, 2014 Share Posted December 23, 2014 BCM also controls hazards....oh for the good old (cheap) indicator relay. Ha, showing your age now, or am i for thinking that in the first place? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 23, 2014 Share Posted December 23, 2014 LOL! Both! I miss the days when you could replace relatively simple parts to cure a fault, rather than having to replace a complete module to fix the same fault with a cost of hundreds, instead of tens of pounds. 1 Quote Link to comment Share on other sites More sharing options...
Ricey Posted December 23, 2014 Share Posted December 23, 2014 LOL! Both! I miss the days when you could replace relatively simple parts to cure a fault, rather than having to replace a complete module to fix the same fault with a cost of hundreds, instead of tens of pounds. I'm only 32 and I miss those days! 1 Quote Link to comment Share on other sites More sharing options...
Madhatter Posted December 24, 2014 Author Share Posted December 24, 2014 Thanks all. Ouch, sounds expensive and stupid Can I just replace or do I have to go to the stealership to have it replaced? Quote Link to comment Share on other sites More sharing options...
ChrisS Posted December 24, 2014 Share Posted December 24, 2014 Thanks all. Ouch, sounds expensive and stupid Can I just replace or do I have to go to the stealership to have it replaced? I'd suggest give Alex or Lee ( R35LEE ) a shout. Quote Link to comment Share on other sites More sharing options...
marzman Posted December 24, 2014 Share Posted December 24, 2014 Probably is the BCM, but as an alternative you're not having battery problems are you? I remember on my first zed, when my battery was almost flat (i'd jumped it earlier that week), my headlights got stuck on and wouldnt turn off at all. Easily fixed by getting a new battery. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted December 25, 2014 Share Posted December 25, 2014 I have 3 BCM's in the cupboard Quote Link to comment Share on other sites More sharing options...
R35LEE Posted December 25, 2014 Share Posted December 25, 2014 And IPDM units of it turns out to be that causing the gremlins. Quote Link to comment Share on other sites More sharing options...
SyMan80 Posted October 15, 2020 Share Posted October 15, 2020 Hi, I've got the same problem how did you fix it?? Thanks . Simon Quote Link to comment Share on other sites More sharing options...
R35LEE Posted October 15, 2020 Share Posted October 15, 2020 13 minutes ago, SyMan80 said: Hi, I've got the same problem how did you fix it?? Thanks . Simon Hi Simon, Where are you based? On the cars with this issue we have seen water ingress into the BCM in the driver footwell or into the IPDM unit under the scuttle panel in the engine bay. I would take a look under the bonnet at the IPDM unit. It's on the passenger side under the scuttle panel the there is a rubber one way grommet (as a water drain) underneath the unit. Chances are yours is dislodged and you have had a load of water come through the hole. Look for green discolouration on contacts as that's where the water has been. If it's not that then look at the BCM in the drivers footwell, again looking for signs of water. Last thing is that it could be the switch if a drink has been poured into it. I have all modules and switches in stock if you end up needing any If you don't fancy doing it yourself we can do it at Falcon Performance in Teesside for you. Good luck, Lee :thumbs: Quote Link to comment Share on other sites More sharing options...
SyMan80 Posted October 15, 2020 Share Posted October 15, 2020 Hi Lee, Thanks for your reply, I'm in Bradford. I'll have a look at both the BCM and the IPDM as you suggested, are they both an easy replacement ie just plug the replacement in?? Thanks Simon Quote Link to comment Share on other sites More sharing options...
R35LEE Posted October 15, 2020 Share Posted October 15, 2020 pm sent Quote Link to comment Share on other sites More sharing options...
