Kiwi Paul Posted December 21, 2014 Share Posted December 21, 2014 I've noticed the last couple of trips the dashboard voltmeter is sitting at around 14 volts minimum, sometimes stays around 14.2 volts (although usually eventually drops to 14 volts). I'm sure it used to drop to about 13.7ish a few minutes after starting the car. I'm electrical savvy and know how a charging system works but from anyone's experience of these cars is this likely to be a charging circuit issue or possibly the battery starting to die. It has plenty of pep to start the car and so far is holding it's charge but this started occurring with the first cold weather which is often when batteries start failing. Paul Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 22, 2014 Share Posted December 22, 2014 I think you have answered your own question there, battery's have a harder time when the temps are down. Quote Link to comment Share on other sites More sharing options...
Kiwi Paul Posted December 29, 2014 Author Share Posted December 29, 2014 Problem solved, I was right about the winter chill, batteries resistance increases with lower temp and the charger compensates by increasing voltage so no issues at all. This is the first car I've owned with a voltmeter so not familiar watching the voltage change over the seasons. Quote Link to comment Share on other sites More sharing options...
