Berk Decats, JIC Y pipe
goodatcrashing
Hello all, a few parts going below. Based in Manchester.
Eibach wheel spacers - 2 X 20mm, 2 X 25mm. Good condition, some degreaser will have them gleaming, supplied with 20 nuts as 5 have rounded, all studs are in good condition - no cross threading. They are £1 per nut on ebay.
SOLD.
Tein lowering springs. Less than 2000 miles use, excellent condition, comes with original box
SOLD
Berk technology decats. DE fitment, 2.5" bore, integrated O2 sensor spacer, T304 grade stainless steel, mandrel bent and Tig welded. A good polish will make them shiney again.
£100 + postage
JIC Y pipe. One of the joints is blowing slightly. Replacement joint can be had for £25. Good condition otherwise.
£90 + postage
Edited by goodatcrashing
Im pretty sure the dampers are the same part number on coupe and roadster, so assume they would fit. Might be worth asking around to be 100%?
Spacers are not needed for the wheels. They fit direct onto the standard hubs. If you want to push them a little wider, the spacers can achieve this.
I'd prefer the wheels to be either picked up or arranged via courier of your choice. That way you could find the best deal as there will be a considerable range.
  • 2 months later...
