d0minator33 Posted December 3, 2014 Share Posted December 3, 2014 Hey guys so I've got a couple of problems the first and probably small 1 is my exhaust seems to of gotten much louder for no reason and I mean ear bleeding loud I suspect back box but I looked under and couldn't see a problem. The bigger problem Is my 6th gear frequently grinding as I goes in usually when I give it a bit of revs. Are these common issues? My car is 58 plate with 29k miles on it. thanks for the help in advance Quote Link to comment Share on other sites More sharing options...
martybhoy Posted December 3, 2014 Share Posted December 3, 2014 I thought my 6th was grinding a little but I was being a bit fly when pressing the clutch Quote Link to comment Share on other sites More sharing options...
Lexx Posted December 3, 2014 Share Posted December 3, 2014 Exhaust likely parted from the back box due to failed welds. You'll need to get right under the car to check. Grinding into gear could be synchromesh, although unusual at such low mileage. Quote Link to comment Share on other sites More sharing options...
comrade Posted December 3, 2014 Share Posted December 3, 2014 Exhaust is either the joint between the back box and the middle pipe, or a flexi on the Y-pipe. You can it welded for £20-£30. Quote Link to comment Share on other sites More sharing options...
StevoD Posted December 3, 2014 Share Posted December 3, 2014 your lucky youve only got 2 some people recon they have 99 and both semi common issue tho Quote Link to comment Share on other sites More sharing options...
d0minator33 Posted December 3, 2014 Author Share Posted December 3, 2014 Cheers guys i found the failed welding near the back box so at least thats not a big problem ill see how 6 gear goes for now if it gets any worse ill get it down the garage. Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted December 3, 2014 Share Posted December 3, 2014 Don't look at them as problems, they are opportunities. NEW EXHAUST TIME! Or get it repaired which is the boring but cheaper route. Can't help on the 6th gear I'm afraid. Quote Link to comment Share on other sites More sharing options...
KyleR Posted December 3, 2014 Share Posted December 3, 2014 Common problem in the gearboxes, rarer in the newer boxes like yours, especially at such low mileage. Double clutch into 6th or try Rev match and it'll be fine. Quote Link to comment Share on other sites More sharing options...
Jp606 Posted December 5, 2014 Share Posted December 5, 2014 My 6th sometimes does that, when it's a bit cold usually. Also a HR with fairly low miles. Quote Link to comment Share on other sites More sharing options...
