brake lights -abs,traction control,skid
Raheemk9
I am hoping someone can help me I have a issue and it is really bugging me.
Every time I press my brake pedal when I start driving my abs traction and skid lights all come on and stay on and also my brake light are really dim and sometimes they stop working aswell.
Winter is coming and I really need my traction working and my brake light .
Thank you
As you mention the brake lights are dim I'd suggest its probably the brake pedal switch, really easy to change and doesn't cost much.
I had those lights come on and dim brake lights and it turned out it was the brake pedal switch.
https://cornerbalance.wordpress.com/2013/01/26/diy-350zg35-brake-lights-dont-work-aka-the-easiest-install-youll-ever-do/
I had the exact same problem.
Check out the switch behind the brake pedal.
You may be lucky and it just came loose when vacuuming around the mats there in which case just undo and re tightened.
Takes minutes to fix :thumbs:
