350z Drivers side door catch/ mechanism ????
Y23DRH
Need one of these for a 2005 350z roadster
Drivers Door was stuck closed managed to get the door card off and used the good old coat hanger trick to open the door :)
I found that The small metal rod with the blue clip goes down but won't come back up to let you open the car door with the out side handle unless you manually pull the metal rod each time to open the door
not sure if it's the out side door handle that's the problem or the door catch / mechanism etc the central locking works fine and both the passenger door and boot open fine just drivers door that's being a sod
I have attached a few pics
So people can see what im looking for
th_DSC_0155_zps4aozvmlw.jpg[/url]
Hopefully these pictures have helped
